Microsoft Surface Laptop 3 13.5" Feet Replacement
Выберете то, что вам нужно
  1. Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: шаг 1, изображение 1 из 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: шаг 1, изображение 2 из 2
    • Flip the laptop over and place it on your work surface, feet facing up.
  2. Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: шаг 2, изображение 1 из 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: шаг 2, изображение 2 из 2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  3. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: шаг 3, изображение 1 из 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: шаг 3, изображение 2 из 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: шаг 3, изображение 3 из 3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  4. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: шаг 4, изображение 1 из 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: шаг 4, изображение 2 из 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: шаг 4, изображение 3 из 3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  5. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: шаг 5, изображение 1 из 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: шаг 5, изображение 2 из 2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  6. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: шаг 6, изображение 1 из 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: шаг 6, изображение 2 из 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: шаг 6, изображение 3 из 3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Еще один человек закончил это руководство.
Carsten Frauenheim
Участник с: 03/10/20
114 671 Репутация
Автор 339 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 303 руководств
Один комментарий
Nice, that good for me, first time :D
TrungLun0112 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 24
За последние 30 дней: 161
За всё время: 5,772
