Microsoft Surface Laptop 3 13.5" SSD Replacement
Выберете то, что вам нужно
  1. Microsoft Surface Laptop 3 13.5" SSD Replacement, Flip the laptop over: шаг 1, изображение 1 из 2 Microsoft Surface Laptop 3 13.5" SSD Replacement, Flip the laptop over: шаг 1, изображение 2 из 2
    • Flip the laptop over and place it on your work surface, feet facing up.
  2. Microsoft Surface Laptop 3 13.5" SSD Replacement, Removal tip: шаг 2, изображение 1 из 2 Microsoft Surface Laptop 3 13.5" SSD Replacement, Removal tip: шаг 2, изображение 2 из 2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  3. Microsoft Surface Laptop 3 13.5" SSD Replacement, Remove the rear feet: шаг 3, изображение 1 из 3 Microsoft Surface Laptop 3 13.5" SSD Replacement, Remove the rear feet: шаг 3, изображение 2 из 3 Microsoft Surface Laptop 3 13.5" SSD Replacement, Remove the rear feet: шаг 3, изображение 3 из 3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  4. Microsoft Surface Laptop 3 13.5" SSD Replacement, Remove the front feet: шаг 4, изображение 1 из 3 Microsoft Surface Laptop 3 13.5" SSD Replacement, Remove the front feet: шаг 4, изображение 2 из 3 Microsoft Surface Laptop 3 13.5" SSD Replacement, Remove the front feet: шаг 4, изображение 3 из 3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  5. Microsoft Surface Laptop 3 13.5" SSD Replacement, Reassembly tip: шаг 5, изображение 1 из 2 Microsoft Surface Laptop 3 13.5" SSD Replacement, Reassembly tip: шаг 5, изображение 2 из 2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  6. Microsoft Surface Laptop 3 13.5" SSD Replacement, Reassembly tip: шаг 6, изображение 1 из 3 Microsoft Surface Laptop 3 13.5" SSD Replacement, Reassembly tip: шаг 6, изображение 2 из 3 Microsoft Surface Laptop 3 13.5" SSD Replacement, Reassembly tip: шаг 6, изображение 3 из 3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
  7. Microsoft Surface Laptop 3 13.5" SSD Replacement, Remove the upper case screws: шаг 7, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    Купить
    • Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
    • During reassembly, don't over-tighten these screws—they strip easily.
  8. Microsoft Surface Laptop 3 13.5" SSD Replacement, Open the display: шаг 8, изображение 1 из 3 Microsoft Surface Laptop 3 13.5" SSD Replacement, Open the display: шаг 8, изображение 2 из 3 Microsoft Surface Laptop 3 13.5" SSD Replacement, Open the display: шаг 8, изображение 3 из 3
    • Flip the device over.
    • Open the display as far as it will go.
  9. Microsoft Surface Laptop 3 13.5" SSD Replacement, Lift up the upper case: шаг 9, изображение 1 из 3 Microsoft Surface Laptop 3 13.5" SSD Replacement, Lift up the upper case: шаг 9, изображение 2 из 3 Microsoft Surface Laptop 3 13.5" SSD Replacement, Lift up the upper case: шаг 9, изображение 3 из 3
    • The upper case is secured in place by magnets.
    • Grip the top edge of upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case just yet, as it's still connected to the rest of the laptop.
    • Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the display could cause damage to the display as it closes.
  10. Microsoft Surface Laptop 3 13.5" SSD Replacement, Disconnect the ribbon cable: шаг 10, изображение 1 из 3 Microsoft Surface Laptop 3 13.5" SSD Replacement, Disconnect the ribbon cable: шаг 10, изображение 2 из 3 Microsoft Surface Laptop 3 13.5" SSD Replacement, Disconnect the ribbon cable: шаг 10, изображение 3 из 3
    • The keyboard and touchpad ribbon cable is secured in place by a magnet connector.
    • On some models, this connector is surrounded by black tape.
    • Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
    • Remove the ribbon cable from the motherboard.
  11. Microsoft Surface Laptop 3 13.5" SSD Replacement, Remove the upper case: шаг 11, изображение 1 из 2 Microsoft Surface Laptop 3 13.5" SSD Replacement, Remove the upper case: шаг 11, изображение 2 из 2
    • Remove the upper case.
    • Set the upper case onto a clean surface, keyboard-side down.
    • Ensure the ribbon cable lays flat, and isn't twisted or stressed.
  12. Microsoft Surface Laptop 3 13.5" SSD Replacement, Remove the SSD screw: шаг 12, изображение 1 из 1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be performed before all major repairs.
  13. Microsoft Surface Laptop 3 13.5" SSD Replacement, Remove the SSD: шаг 13, изображение 1 из 2 Microsoft Surface Laptop 3 13.5" SSD Replacement, Remove the SSD: шаг 13, изображение 2 из 2
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
11 участников успешно повторили данное руководство.
Carsten Frauenheim
Участник с: 03/10/20
114 572 Репутация
Автор 339 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 298 руководств
7 Комментариев
what is the type of ssd on the laptop 3 sufrace ?
and what is the best brand for the ssd ?
Hamad Al kherejy - Ответить
Hi, it supports M.2 2230 ssd. The best one I found is from Kioxia (Toshiba)
Suresh Aryal -
Another option is the Sabrent Rocket 256/512/1024GB 2230 model.
Mark Spencer -
I replaced the "Microsoft" SSD with an SSD labeled "Samsung" to upgrade from 128GB to 512GB. Benchmarks after the change showed a 2-3x increase in random read and write speeds! Not sure if what I installed was counterfieit because the SSD I installed did not have the standard Samung labeling and was not recognized by the Samsung software ... but everything seems to work ok and I'm pleased to have the increased speed.
Andornot -
Can you put a new drive that has higher capacity?
Jon - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 52
За последние 7 дней: 343
За последние 30 дней: 1,428
За всё время: 32,309
