Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement
Выберете то, что вам нужно
  1. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Prepare your laptop for disassembly: шаг 1, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Prepare your laptop for disassembly: шаг 1, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Prepare your laptop for disassembly: шаг 1, изображение 3 из 3
    • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Flip your laptop over: шаг 2, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Flip your laptop over: шаг 2, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Flip your laptop over: шаг 2, изображение 3 из 3
    • Close your laptop and lay it down so the rubber feet are facing up.
  3. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the feet: шаг 3, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the feet: шаг 3, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the feet: шаг 3, изображение 3 из 3
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
  4. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the lower case screws: шаг 4, изображение 1 из 2 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the lower case screws: шаг 4, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    FixMat
    $36.95
    • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
  5. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Detach the lower case: шаг 5, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Detach the lower case: шаг 5, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Detach the lower case: шаг 5, изображение 3 из 3
    • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
    • Don't insert the pick near the outer edges or you'll damage the antenna bar.
  6. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 6, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 6, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 6, изображение 3 из 3
    • Twist the pick to lift the lower case enough that you can grip it with your hand.
  7. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the lower case: шаг 7, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the lower case: шаг 7, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the lower case: шаг 7, изображение 3 из 3
    • Lift the lower case and remove it.
  8. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Disconnect the battery: шаг 8, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Disconnect the battery: шаг 8, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Disconnect the battery: шаг 8, изображение 3 из 3
    • Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
  9. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 9, изображение 1 из 2 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 9, изображение 2 из 2
    • Use tweezers or your fingers to remove the battery connector cover.
  10. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 10, изображение 1 из 2 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 10, изображение 2 из 2
    • Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It may take a few tries to align the connector—don't try to force it into place.
  11. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the motherboard shield: шаг 11, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the motherboard shield: шаг 11, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the motherboard shield: шаг 11, изображение 3 из 3
    • When removing the motherboard shield in the next few steps, try to deform the shield as little as possible. You'll need to reuse it during reassembly.
    • Slide one arm of a pair of angled tweezers into one of the gaps on the edge of the display cable shield.
    • Use your tweezers to pry up and unclip the shield.
  12. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 12, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 12, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 12, изображение 3 из 3
    • Continue unclipping the edges of the shield until you can grip it with your fingers.
    • Use your fingers to grip the shield and fully remove it.
    • If the shield feels stuck, use your tweezers to unclip the area that's stuck.
  13. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the heat sink: шаг 13, изображение 1 из 2 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the heat sink: шаг 13, изображение 2 из 2
    • Use a Torx Plus 3IP screwdriver to remove the five screws securing the heat sink:
    • Four 3.2 mm‑long CPU tension screws
    • One 2.7 mm‑long screw near the top left side
    • During reassembly, tighten the four CPU tension screws in an "X" pattern. For example, top left, bottom right, top right, bottom left.
  14. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 14, изображение 1 из 2 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 14, изображение 2 из 2
    • Thermal paste bonds the heat sink to the CPU. The strength of the bond will vary depending on the age of your laptop and condition of the paste.
    • Insert the flat end of a spudger under the left CPU tension bracket and lift to separate the heat sink.
    • Be very careful not to scrape or damage any of the small surface-mounted components on the motherboard.
  15. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 15, изображение 1 из 1
    • Lift the heat sink straight up and remove it.
    • During reassembly, carefully put the heat sink into place, using the alignment peg to orient it. Try not to move the heat sink once it's in place, or you may unevenly smear the thermal paste.
  16. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the old thermal paste: шаг 16, изображение 1 из 2 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Remove the old thermal paste: шаг 16, изображение 2 из 2
    • Before installing a new heat sink, you must remove all the old thermal paste from the CPU surface.
    • Use the flat end of a spudger to scrape up the old thermal paste from the CPU.
    • Use high concentration (more than 90%) isopropyl alcohol and a microfiber cleaning cloth to remove all the thermal paste residue from the CPU.
    • Don't touch the CPU or let any dust or debris settle on it—even a fingerprint can interfere with heat dissipation.
    • Wait for the isopropyl alcohol to dry completely before applying any thermal paste.
  17. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 17, изображение 1 из 2 Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement: шаг 17, изображение 2 из 2
    • If you're replacing the heat sink, skip this step.
    • Repeat the previous step to remove all the thermal paste and its residue from the bottom of the heat sink.
  18. Microsoft Surface Laptop 7 (13.8-inch) Heat Sink Replacement, Apply new thermal paste: шаг 18, изображение 1 из 1
    • Apply a very small dot of thermal paste to the center of the CPU—about the size of a small matchstick head. There only needs to be enough for a thin layer to cover the CPU.
Заключение
To reassemble your device, follow these instructions in reverse order starting with this step.
Spencer Day
Участник с: 09/14/22
95 827 Репутация
Автор 662 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 632 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 5
За последние 30 дней: 30
За всё время: 279
