Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement
Выберете то, что вам нужно
  1. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Prepare your laptop for disassembly: шаг 1, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Prepare your laptop for disassembly: шаг 1, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Prepare your laptop for disassembly: шаг 1, изображение 3 из 3
    • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Flip your laptop over: шаг 2, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Flip your laptop over: шаг 2, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Flip your laptop over: шаг 2, изображение 3 из 3
    • Close your laptop and lay it down so the rubber feet are facing up.
  3. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the feet: шаг 3, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the feet: шаг 3, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the feet: шаг 3, изображение 3 из 3
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
  4. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case screws: шаг 4, изображение 1 из 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case screws: шаг 4, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    FixMat
    $36.95
    • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
  5. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Detach the lower case: шаг 5, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Detach the lower case: шаг 5, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Detach the lower case: шаг 5, изображение 3 из 3
    • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
    • Don't insert the pick near the outer edges or you'll damage the antenna bar.
  6. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: шаг 6, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: шаг 6, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: шаг 6, изображение 3 из 3
    • Twist the pick to lift the lower case enough that you can grip it with your hand.
  7. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case: шаг 7, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case: шаг 7, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case: шаг 7, изображение 3 из 3
    • Lift the lower case and remove it.
  8. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the battery: шаг 8, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the battery: шаг 8, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the battery: шаг 8, изображение 3 из 3
    • Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
  9. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: шаг 9, изображение 1 из 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: шаг 9, изображение 2 из 2
    • Use tweezers or your fingers to remove the battery connector cover.
  10. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: шаг 10, изображение 1 из 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: шаг 10, изображение 2 из 2
    • Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It may take a few tries to align the connector—don't try to force it into place.
  11. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the speaker: шаг 11, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the speaker: шаг 11, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the speaker: шаг 11, изображение 3 из 3
    • The left speaker will be on your right-hand side, since the laptop is laying upside down.
    • Slide the point of a spudger under the left speaker connector and gently lift it straight up and out of the socket.
    • Don't lift on the cables themselves, or you may damage them.
    • During reassembly, hold the connector over its socket and press down gently with the flat end of a spudger until it clicks into place. If you're having trouble, don't try to force the connector into its socket—reposition it and try again.
  12. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the speaker: шаг 12, изображение 1 из 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the speaker: шаг 12, изображение 2 из 2
    • Use a Torx Plus 3IP screwdriver to remove the two 3.2 mm‑long screws securing the left speaker.
  13. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: шаг 13, изображение 1 из 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: шаг 13, изображение 2 из 2
    • Remove the speaker.
    • During reassembly, place the speaker onto the frame so the grommets on the right edge go over their screw posts.
  14. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Reassembly information: шаг 14, изображение 1 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Reassembly information: шаг 14, изображение 2 из 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Reassembly information: шаг 14, изображение 3 из 3
    • Make sure your replacement speaker has two rubber grommets installed on its right edge.
    • If it doesn't, remove the grommets from your old speaker and install them in your replacement.
    • Installing these can be tricky. Use your fingers to pinch the grommet and slide it into its notch.
Заключение
Spencer Day
Участник с: 09/14/22
95 827 Репутация
Автор 662 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 632 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 15
За всё время: 140
