Microsoft Zune 30 GB Button pad Replacement
Выберете то, что вам нужно
  1. Microsoft Zune 30 GB Button pad Replacement, Back Case: шаг 1, изображение 1 из 2 Microsoft Zune 30 GB Button pad Replacement, Back Case: шаг 1, изображение 2 из 2
    • Remove the plastic screw cover located on the bottom of the device. Insert a small flat-headed screwdriver into one side of the cover and gently ease it out. Repeat on the other side.
    • Be gentle when removing the screw cover as it is brittle and will break if forced.
    • You will need a #00 Phillips screwdriver to remove the two 2.6 mm screws that are exposed.
  2. Microsoft Zune 30 GB Button pad Replacement: шаг 2, изображение 1 из 1
    • Use the blue plastic opening tool to slowly work your way around the edges of the case, releasing the front plate from the bottom case.
    • Be gentle when prying the device open.
  3. Microsoft Zune 30 GB Button pad Replacement: шаг 3, изображение 1 из 2 Microsoft Zune 30 GB Button pad Replacement: шаг 3, изображение 2 из 2
    • Turn the Zune over so the screen faces downward. This will ensure the battery does not fall out and pull on the cable.
    • The battery is not fastened to the inside of the case. It will fall out.
    • Pry up from the bottom of the Zune because the headphone jack will not allow you to remove the back case in one pull. You must slide the case up and away from the rest of the Zune.
    • The case is now separated. You can replace the case, if needed.
  4. Microsoft Zune 30 GB Button pad Replacement, Battery: шаг 4, изображение 1 из 2 Microsoft Zune 30 GB Button pad Replacement, Battery: шаг 4, изображение 2 из 2
    • With the Zune facing down, as pictured, the battery ribbon cable is attached to the bottom right hand side of the logic board.
    • Use the small flat head screw driver to gently lift the brown clamp.
    • The clamp will release the battery ribbon cable from the logic board, freeing the battery.
  5. Microsoft Zune 30 GB Button pad Replacement: шаг 5, изображение 1 из 1
    • You can now replace the battery.
    • The battery is a Lithium ion 3.7 V.
  6. Microsoft Zune 30 GB Button pad Replacement, Hard Drive: шаг 6, изображение 1 из 1
    • Now the back cover is off and the battery is removed, so the hard drive is clearly visible.
    • There are four 4.2 mm screws securing the hard drive to the logic board.
    • Remove all four screws using a Phillips #00 screwdriver.
    • Don't lose any of the screws! If necessary, use a magnetized screw driver.
  7. Microsoft Zune 30 GB Button pad Replacement: шаг 7, изображение 1 из 1
    • Carefully tilt the hard drive up from the logic board.
    • Do not pull the hard drive all the way off. It is still connected to the logic board by a ribbon cable.
  8. Microsoft Zune 30 GB Button pad Replacement: шаг 8, изображение 1 из 1
    • Flip the hard drive over the top to expose the ribbon cable.
  9. Microsoft Zune 30 GB Button pad Replacement: шаг 9, изображение 1 из 2 Microsoft Zune 30 GB Button pad Replacement: шаг 9, изображение 2 из 2
    • This may be difficult to move, so take your time and be careful.
    • The ribbon cable is held in place by a black latch on the hard drive.
    • Using a small flat head screwdriver, flip the black latch up 90 degrees.
    • Make sure you are only flipping the black latch. Do not try to lift any wires or the white connector piece.
  10. Microsoft Zune 30 GB Button pad Replacement: шаг 10, изображение 1 из 2 Microsoft Zune 30 GB Button pad Replacement: шаг 10, изображение 2 из 2
    • Carefully detach the ribbon cable from the hard drive.
    • Now you have completely detached the hard drive.
  11. Microsoft Zune 30 GB Button pad Replacement, Logic Board: шаг 11, изображение 1 из 2 Microsoft Zune 30 GB Button pad Replacement, Logic Board: шаг 11, изображение 2 из 2
    • The ribbon cable for the button sensor pad is attached with a small clamp to the bottom left corner of the logic board.
    • Use a small flathead screwdriver to lift the brown clasp and remove the ribbon cable.
  12. Microsoft Zune 30 GB Button pad Replacement: шаг 12, изображение 1 из 1
    • With a Philips #00 screwdriver, remove the six 4.2 mm screws that attach the logic board to the front plate.
  13. Microsoft Zune 30 GB Button pad Replacement: шаг 13, изображение 1 из 2 Microsoft Zune 30 GB Button pad Replacement: шаг 13, изображение 2 из 2
    • Carefully lift the logic board off of the front plate.
    • The button pad is free underneath and can fall out. Make sure to place it in a secure place.
    • The logic board is now free.
    • Follow the LCD repair guide to detach LCD display from logic board.
  14. Microsoft Zune 30 GB Button pad Replacement, Button pad: шаг 14, изображение 1 из 1
    • The button assembly is made up of three layers, stacked on two plastic pins protruding from the front plate.
    • Unscrew the two plastic pins and the four metal screws with the Philips #00 screwdriver.
  15. Microsoft Zune 30 GB Button pad Replacement: шаг 15, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Купить
    • Remove the metal backing plate.
    • Remove the paper shield with tweezers.
  16. Microsoft Zune 30 GB Button pad Replacement: шаг 16, изображение 1 из 2 Microsoft Zune 30 GB Button pad Replacement: шаг 16, изображение 2 из 2
    • Remove the yellow button sensor pad.
Заключение
3 участников успешно повторили данное руководство.
Andrew Optimus Goldheart
Участник с: 10/17/09
503 079 Репутация
Автор 407 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 292 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 31
За всё время: 6,236
