Nexus 6 Rear Facing Camera Replacement
Выберете то, что вам нужно
  1. Nexus 6 Rear Facing Camera Replacement, SIM Card: шаг 1, изображение 1 из 1
    • With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
    • Remove the SIM card and the SIM card holder.
  2. Nexus 6 Rear Facing Camera Replacement, Rear Case: шаг 2, изображение 1 из 2 Nexus 6 Rear Facing Camera Replacement, Rear Case: шаг 2, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    iOpener
    $14.99
    • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
    • Pry open the back casing using the soft plastic opening pick.
    • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
    • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
    • You may need an iOpener to loosen up the adhesive. Check out the iOpener Instructions for info on how to use it.
  3. Nexus 6 Rear Facing Camera Replacement: шаг 3, изображение 1 из 1
    • Remove the twenty-two 2.3 mm T3 Torx screws with the T3 Torx Screwdriver.
  4. Nexus 6 Rear Facing Camera Replacement: шаг 4, изображение 1 из 3 Nexus 6 Rear Facing Camera Replacement: шаг 4, изображение 2 из 3 Nexus 6 Rear Facing Camera Replacement: шаг 4, изображение 3 из 3
    • With tweezers, remove the rubber protector on the lower part of the phone.
    • Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
    • Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
  5. Nexus 6 Rear Facing Camera Replacement, Rear Facing Camera: шаг 5, изображение 1 из 2 Nexus 6 Rear Facing Camera Replacement, Rear Facing Camera: шаг 5, изображение 2 из 2
    • Use the spudger to release the rear facing camera connector.
    • Use tweezers to gently remove the rear facing camera.
Заключение
7 человек успешно провели ремонт по этому руководству.
Marina Moore
Участник с: 01/13/15
4 302 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 70-3, Forte Winter 2015 Участник Cal Poly, Team 70-3, Forte Winter 2015
CPSU-FORTE-W15S70G3
4 членов
Автор 30 руководств
3 Комментарии к руководству
Even though I followed the guide, step by step, and heeded all the advice, once reassembled I cannot get the phone to restart.
Charles Brittain - Ответить Поделиться
check the power and volume ribbon cable and the connector at the top left of the device, it could be loose..
hussain alshaykhnasir - Поделиться
I had the same problem. But it resolved itself when I connected the charger to the phone.
Thomas Boehm - Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 56
За всё время: 5,295
