Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use a SIM card eject tool, to pop out and remove the SIM card tray.
Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
Slide the opening pick underneath the plastic cover to cut the adhesive.
Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
Pry off the glass cover.
Remove the six Phillips #00 screws.
Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
Insert a second opening pick and slide it to the top left corner.
Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
Remove the rear cover.
11 участников успешно повторили данное руководство.
Один комментарий
The first picture of Step-6 is very misleading when looking at guitar pick.
By mistake, I pulled apart my front glass from digitizer by taking the pic as reference.
