Введение
Follow this guide to replace, upgrade, or customize the bottom shell (aka back shell, rear shell, or back cover) on your Nintendo Game Boy Advance SP.
If you're completely re‑shelling your Game Boy, follow this guide.
The Game Boy Advance SP uses JIS screws. If you use a non-iFixit Phillips driver in JIS screws, you'll risk stripping them. iFixit's Phillips bits are designed to be compatible with JIS screws.
Выберете то, что вам нужно
Slide the power switch to the OFF position and unplug any cables.
If you have a game cartridge in, remove it.
Use a JIS 00 screwdriver to loosen the captive screw securing the battery cover.
Use a tri‑point Y0 screwdriver to remove the six screws securing the bottom shell:
Four 6.3 mm‑long recessed screws
Two 4.6 mm‑long screws
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
21 человек успешно провели ремонт по этому руководству.
