Nintendo GameCube Controller Rumble Motor Replacement
Выберете то, что вам нужно
  1. Nintendo GameCube Controller Rumble Motor Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    Спросите у FixBot
    Добавить комментарий
  2. Nintendo GameCube Controller Rumble Motor Replacement: шаг 2, изображение 1 из 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    Спросите у FixBot
  3. Nintendo GameCube Controller Rumble Motor Replacement, Z Button: шаг 3, изображение 1 из 2 Nintendo GameCube Controller Rumble Motor Replacement, Z Button: шаг 3, изображение 2 из 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    Спросите у FixBot
  4. Nintendo GameCube Controller Rumble Motor Replacement, Circuit Board: шаг 4, изображение 1 из 1
    • Carefully unhook the cable that is looped around the peg.
    Спросите у FixBot
  5. Nintendo GameCube Controller Rumble Motor Replacement: шаг 5, изображение 1 из 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
    Спросите у FixBot
  6. Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: шаг 6, изображение 1 из 2 Nintendo GameCube Controller Rumble Motor Replacement, Rumble Motor: шаг 6, изображение 2 из 2
    • Press the tip of the soldering iron against one of the leads and wait until solder is viscous. Carefully pull wire away from lead.
    • Repeat for the second lead and wire.
    • During reassembly, solder the white wire to (+) lead on the right side, and the black wire to the (-) lead on the left side.
    • For more information, please refer to this soldering guide.
    Спросите у FixBot
  7. Nintendo GameCube Controller Rumble Motor Replacement: шаг 7, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Using tweezers, unhook the wires from the small black bracket keeping them attached to the circuit board.
    Спросите у FixBot
  8. Nintendo GameCube Controller Rumble Motor Replacement: шаг 8, изображение 1 из 1
    • Lift the motor out of the bracket.
    • Remember to not pull by the wires! This can make your repair a lot more complicated.
    Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Sean Michel
Участник с: 01/14/13
2 750 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 19-44, Regan Winter 2013 Участник Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 членов
Автор 34 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 10
За последние 7 дней: 41
За последние 30 дней: 161
За всё время: 17,946
