Nintendo Wii Remote Motherboard Replacement
Выберете то, что вам нужно
  1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: шаг 1, изображение 1 из 2 Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: шаг 1, изображение 2 из 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    my battery cover is different. The batteries are attached to the actual cover and come out when the back is removed.
    Kim Pearson - Ответить
  2. Nintendo Wii Remote Motherboard Replacement: шаг 2, изображение 1 из 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Motherboard Replacement: шаг 3, изображение 1 из 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Motherboard Replacement: шаг 4, изображение 1 из 2 Nintendo Wii Remote Motherboard Replacement: шаг 4, изображение 2 из 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Mine is not opening like a book? What do I do?
    Micah Thompson - Ответить
    It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
    Sticky Insides - Ответить
  5. Nintendo Wii Remote Motherboard Replacement, Motherboard: шаг 5, изображение 1 из 2 Nintendo Wii Remote Motherboard Replacement, Motherboard: шаг 5, изображение 2 из 2
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
  6. Nintendo Wii Remote Motherboard Replacement: шаг 6, изображение 1 из 2 Nintendo Wii Remote Motherboard Replacement: шаг 6, изображение 2 из 2
    • Grasp the edges of the motherboard and pull it straight away from the case.
Заключение
31 человек успешно провели ремонт по этому руководству.
Emily
Участник с: 04/14/13
1 803 Репутация
Автор 6 руководств
Команду
Cal Poly, Team 3-44, Amido Spring 2013 Участник Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 членов
Автор 28 руководств
7Комментарии к руководству
Where do you find a motherboard and how much do they typically cost?
Jeff - Ответить
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - Ответить
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign -
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - Ответить
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - Ответить
Just adding a comment to dispute the above suggestion that “this is useless”. I used this guide to help repair a damaged Wii Controller which had had some battery leakage onto the mainboard. I was able to open the controller, clean up (using vinegar and water) the battery corrosion and re-assemble the controller. It works fine again now and I used this guide to find out that there are plastic clips holding the case together.
Sylph Hawkins - Ответить
I can't sync my Wii balance board. and remote at the same time. when the Wii remotes sync the balance board goes out and vice versa
Geraldine Cartagena - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 6
За последние 7 дней: 56
За последние 30 дней: 337
За всё время: 35,133
