OnePlus Nord Battery Replacement
Выберете то, что вам нужно
  1. OnePlus Nord Battery Replacement, Loosen the rear glass adhesive: шаг 1, изображение 1 из 1
    • Switch off your phone.
    • Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. If you have a heatbed with precise temperature control (like any FDM 3D printer with heatbed) 45°C is enough. You might want to repeat this step several times during the rear glass removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. OnePlus Nord Battery Replacement, Create a gap: шаг 2, изображение 1 из 2 OnePlus Nord Battery Replacement, Create a gap: шаг 2, изображение 2 из 2
    • Apply a suction cup to the back of the phone, as close as possible to the center of the right edge.
    • Pull on the suction cup to create a gap between the rear glass and the frame.
    • Insert an opening pick into the gap.
  3. OnePlus Nord Battery Replacement, Slice the adhesive: шаг 3, изображение 1 из 2 OnePlus Nord Battery Replacement, Slice the adhesive: шаг 3, изображение 2 из 2
    • Slide the opening pick along the edge to the bottom right corner.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
    • Once you have inserted an opening pick, feel free to remove the suction cup or continue to use it for a better grip during this process.
  4. OnePlus Nord Battery Replacement: шаг 4, изображение 1 из 3 OnePlus Nord Battery Replacement: шаг 4, изображение 2 из 3 OnePlus Nord Battery Replacement: шаг 4, изображение 3 из 3
    • Insert a second opening pick under the bottom right corner.
    • Slide the opening pick along the edge to the top right corner.
    • If you have trouble with cutting, you can use the iOpener again to soften the adhesive.
  5. OnePlus Nord Battery Replacement: шаг 5, изображение 1 из 3 OnePlus Nord Battery Replacement: шаг 5, изображение 2 из 3 OnePlus Nord Battery Replacement: шаг 5, изображение 3 из 3
    • Insert a third opening pick under the top right corner of the back cover.
    • Slide the tip of the opening pick along the edge of the phone to the top left corner to cut the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. OnePlus Nord Battery Replacement: шаг 6, изображение 1 из 3 OnePlus Nord Battery Replacement: шаг 6, изображение 2 из 3 OnePlus Nord Battery Replacement: шаг 6, изображение 3 из 3
    • Insert a fourth opening pick under the top left corner.
    • Slide the opening pick along the edge to the bottom left corner to cut the adhesive.
  7. OnePlus Nord Battery Replacement: шаг 7, изображение 1 из 2 OnePlus Nord Battery Replacement: шаг 7, изображение 2 из 2
    • Insert a fifth opening pick under the bottom left corner.
    • Slide it along the the edge to the bottom right corner to cut the remaining adhesive.
  8. OnePlus Nord Battery Replacement, Remove the back cover: шаг 8, изображение 1 из 1
    • Remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. OnePlus Nord Battery Replacement, Remove the motherboard cover: шаг 9, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the ten 3.6 mm-long screws from the motherboard cover.
  10. OnePlus Nord Battery Replacement: шаг 10, изображение 1 из 3 OnePlus Nord Battery Replacement: шаг 10, изображение 2 из 3 OnePlus Nord Battery Replacement: шаг 10, изображение 3 из 3
    • Insert the tip of an opening pick under the motherboard cover.
    • Use the opening pick to lift the motherboard cover up and release the plastic clips that holds the cover in its place.
    • Remove the motherboard cover.
  11. OnePlus Nord Battery Replacement, Disconnect the battery: шаг 11, изображение 1 из 2 OnePlus Nord Battery Replacement, Disconnect the battery: шаг 11, изображение 2 из 2
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
  12. OnePlus Nord Battery Replacement, Remove the battery: шаг 12, изображение 1 из 3 OnePlus Nord Battery Replacement, Remove the battery: шаг 12, изображение 2 из 3 OnePlus Nord Battery Replacement, Remove the battery: шаг 12, изображение 3 из 3
    • Peel back the red pull tab and the black sticker from the edge of the battery.
    • Pull the tab up steadily to break up the adhesive holding the battery in place.
    • If the adhesive is too strong, place a heated iOpener on the screen for two minutes or use a heat gun to soften the adhesive beneath the battery.
  13. OnePlus Nord Battery Replacement: шаг 13, изображение 1 из 1
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • You can reuse the old adhesive tape in case it's still sticky. If you need to remove it, replace it with new custom cut adhesive tape.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
7 участников успешно повторили данное руководство.
Adriana Zwink
Участник с: 12/18/19
48 810 Репутация
Автор 167 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 430 руководств
3 Комментариев
charger plug is not working
Priya Gulati - Ответить
Thanks for the guide, just replaced battery in mine.
Radek Věchet - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 42
За последние 7 дней: 250
За последние 30 дней: 1,009
За всё время: 25,394
