Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
Depress the display latch release button and open your display.
Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
If necessary, remove the strip of tape covering the speaker cables.
Use your fingernails or the tip of a spudger to separate the ZIF cable lock from its socket.
Pull the DC-in ribbon cable straight away from its socket.
Peel the DC-in cable off the adhesive securing it to the lower case.
If necessary, use the tip of a spudger to remove the small piece of foam tape from the side of the left speaker.
De-route the AirPort antenna cables from the channel in the left speaker.
Remove the single 6.9 mm T8 Torx screw securing the left speaker to the lower case.
Lift the left speaker from its rear edge and maneuver it out of the lower case, minding the cables sitting in the channel near the front edge of the left speaker.
Remove the single 6.9 mm T8 Torx screw securing the speaker cable ground loop to the lower case.
Peel back the piece of foil tape covering the modem cable to free the speaker cable held underneath.
Pull the speaker cable straight up to disconnect it from the sound card.
Use the flat end of a spudger to pry the hard drive ribbon cable connector up off the logic board.
Use the flat end of a spudger to pry the sound card cable connector up off the logic board.
Use the flat end of a spudger to pry the optical drive cable connector up off the logic board.
Pull the PRAM battery & USB board cable out of its socket.
Use a spudger to de-route the display data cable from the channel in the right speaker.
Use the tip of a spudger to pry the power button LED window off the right speaker.
Remove the single T8 6.9 mm Torx screw securing the right speaker to the lower case.
De-route the speaker cable from the clips along the front edge of the logic board.
Close your PowerBook, minding any cables that may interfere, and flip it over.
Disconnect the power cable connector by pulling it straight away from its socket on the logic board.
Disconnect the battery cable connector straight away from its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
Use the flat end of a spudger to pry the modem cable connector up off the logic board.
Use the flat end of a spudger to pry the PC card cage cable connector up off the logic board.
Disconnect both of the following connectors from the logic board:
Left fan cable.
Inverter cable.
Remove the following four screws securing the optical drive to the lower case:
Three 6.8 mm T8 Torx.
One 3.8 mm T8 Torx.
Lift the optical drive out of the lower case, minding any cables that may get caught.
If necessary, remove the piece of tape securing the display data cable to the logic board.
Pull the display data cable away from its socket to disconnect it from the logic board.
Disconnect the right fan by pulling its connector away from the socket on the logic board.
Remove the following 12 screws:
Three black 5.7 mm T8 Torx.
Three 7 mm T8 Torx with spring washers.
Three 3.8 mm T8 Torx.
If necessary, use a spudger to pry up the left edge of the logic board to separate the solidified thermal paste from the heat sink.
Lift the logic board from its left edge and rotate it toward the right side of the lower case.
Rotate the logic board until it is nearly vertical, and wiggle it around until it releases from the lower case.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the chip directly out from its connectors.
6 участников успешно повторили данное руководство.
