Выберете то, что вам нужно
Heat the skate using a heat gun or hair dryer.
Using the pointy end of the spudger pry away a corner of the skate.
Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
Repeat these steps for each of the skates.
Remove two 4.8 mm screws that were hidden under the front skates using a JIS #1 screwdriver.
Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
Heat the label gently with a heat gun or hair dryer.
Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
Remove the two 4.8 mm screws using a JIS #1 screwdriver.
Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
Use the flat end of the spudger to pop-out the scroll wheel assembly.
Pull up on the top half of the cable connector and pull the cable from the connector.
Heat the soldering iron to middle high heat.
Inject a small amount of flux onto the LED solder connection you wish to replace.
Place the solder wick on top of the solder joint.
Press the soldering iron on top of the solder wick on top of the solder joint, and press until you see the solder come through the wick.
Once you see the solder through the wick (it should look silver and not copper colored) pull the wick off the solder joint and remove the soldering iron.
Remove the LED with tweezers.
