Введение
If your Razer BlackShark V2 is producing choppy, interrupted, or no audio, your headset’s speaker(s) may be damaged (to confirm diagnoses & solutions, see Razer Blackshark V2 Troubleshooting Page, "Audio Cutting Out" or “No Audio at All”). This guide will assist you in the replacement of this component.. Be sure to be mindful of which layers of the headset assembly you're taking apart and that you don't adversely damage the holds, small wires, ear cushions, ear cushions’ rubber linings or plastic ridges, or headset itself when applying pressure.
Выберете то, что вам нужно
Scoop your middle and ring finger underneath the top or bottom inner portion of the ear cushion.
Pull from the hard plastic ridge, being sure not to pull from the soft cushion.
Remove the four screws holding the speaker in the headset using a Phillips #1 screwdriver.
Gently grab the headset and slowly apply pressure to the speaker cover; it will come off.
With heat or with a sharp tool, remove the glue around the wires that connect the speaker to the headset.
Еще один человек закончил это руководство.
