Razer Blade 15" (2018) Hard Drive Replacement
Выберете то, что вам нужно
    1. Razer Blade 15" (2018) Hard Drive Replacement, Prepare your laptop for disassembly: шаг 1, изображение 1 из 2 Razer Blade 15" (2018) Hard Drive Replacement, Prepare your laptop for disassembly: шаг 1, изображение 2 из 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables, fully shut down your laptop, and close the lid.
      Спросите у FixBot
      Добавить комментарий
    1. Razer Blade 15" (2018) Hard Drive Replacement, Unfasten the back cover: шаг 2, изображение 1 из 1
      • Rotate your laptop so the screen hinge is farthest from you.
      • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
      Спросите у FixBot
    2. Razer Blade 15" (2018) Hard Drive Replacement, Insert an opening pick: шаг 3, изображение 1 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Insert an opening pick: шаг 3, изображение 2 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Insert an opening pick: шаг 3, изображение 3 из 3
      • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
      • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
      • Pull up on the suction handle to create a small gap between the back cover and the frame.
      • Insert an opening pick into the gap.
      Спросите у FixBot
    3. Razer Blade 15" (2018) Hard Drive Replacement, Angle the opening pick: шаг 4, изображение 1 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Angle the opening pick: шаг 4, изображение 2 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Angle the opening pick: шаг 4, изображение 3 из 3
      • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
      • Insert your pick up to 10 mm (0.4 in) deep.
      Спросите у FixBot
    4. Razer Blade 15" (2018) Hard Drive Replacement, Free the bottom right corner: шаг 5, изображение 1 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Free the bottom right corner: шаг 5, изображение 2 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Free the bottom right corner: шаг 5, изображение 3 из 3
      • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
      Спросите у FixBot
    5. Razer Blade 15" (2018) Hard Drive Replacement, Free the front edge: шаг 6, изображение 1 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Free the front edge: шаг 6, изображение 2 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Free the front edge: шаг 6, изображение 3 из 3
      • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
      Спросите у FixBot
    6. Razer Blade 15" (2018) Hard Drive Replacement, Remove the back cover: шаг 7, изображение 1 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Remove the back cover: шаг 7, изображение 2 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Remove the back cover: шаг 7, изображение 3 из 3
      • Remove the back cover.
      • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
      Спросите у FixBot
    1. Razer Blade 15" (2018) Hard Drive Replacement, Soften the battery cable tape adhesive: шаг 8, изображение 1 из 2 Razer Blade 15" (2018) Hard Drive Replacement, Soften the battery cable tape adhesive: шаг 8, изображение 2 из 2
      • Apply a heated iOpener to the battery cable tape for one minute.
      • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
      Спросите у FixBot
    2. Razer Blade 15" (2018) Hard Drive Replacement, Peel up the battery cable tape: шаг 9, изображение 1 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Peel up the battery cable tape: шаг 9, изображение 2 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Peel up the battery cable tape: шаг 9, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      • Be careful not to damage the battery with your tool.
      • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
      Спросите у FixBot
    3. Razer Blade 15" (2018) Hard Drive Replacement, Disconnect the battery: шаг 10, изображение 1 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Disconnect the battery: шаг 10, изображение 2 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Disconnect the battery: шаг 10, изображение 3 из 3
      • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
      Спросите у FixBot
    1. Razer Blade 15" (2018) Hard Drive Replacement, Disconnect the hard drive: шаг 11, изображение 1 из 2 Razer Blade 15" (2018) Hard Drive Replacement, Disconnect the hard drive: шаг 11, изображение 2 из 2
      • Grab the pull tab on the hard drive press connector, just below the right fan.
      • Pull up and disconnect the connector from its socket.
      • During reassembly, align the press connector over its socket and press down until it clicks into place. If it doesn't connect, re-align it and try again.
      Спросите у FixBot
    2. Razer Blade 15" (2018) Hard Drive Replacement, Unfasten the hard drive mounts: шаг 12, изображение 1 из 2 Razer Blade 15" (2018) Hard Drive Replacement, Unfasten the hard drive mounts: шаг 12, изображение 2 из 2
      • Use your Phillips screwdriver to remove the four screws securing the hard drive mounts:
      • Three 3.2 mm screws
      • One 5.2 mm screw
      Спросите у FixBot
    3. Razer Blade 15" (2018) Hard Drive Replacement, Remove the hard drive: шаг 13, изображение 1 из 2 Razer Blade 15" (2018) Hard Drive Replacement, Remove the hard drive: шаг 13, изображение 2 из 2
      • Lift the hard drive straight up to remove it.
      Спросите у FixBot
    1. Razer Blade 15" (2018) Hard Drive Replacement, Hard Drive: шаг 14, изображение 1 из 1
      • Flip the hard drive over.
      Спросите у FixBot
    2. Razer Blade 15" (2018) Hard Drive Replacement, Unfasten the mounts: шаг 15, изображение 1 из 2 Razer Blade 15" (2018) Hard Drive Replacement, Unfasten the mounts: шаг 15, изображение 2 из 2
      • Use your Phillips screwdriver to remove the four 3.9 mm screws securing the two mounts to the hard drive.
      Спросите у FixBot
    3. Razer Blade 15" (2018) Hard Drive Replacement, Remove the mounts: шаг 16, изображение 1 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Remove the mounts: шаг 16, изображение 2 из 3 Razer Blade 15" (2018) Hard Drive Replacement, Remove the mounts: шаг 16, изображение 3 из 3
      • Remove both mounts from the hard drive.
      Спросите у FixBot
    4. Razer Blade 15" (2018) Hard Drive Replacement, Remove the cable: шаг 17, изображение 1 из 2 Razer Blade 15" (2018) Hard Drive Replacement, Remove the cable: шаг 17, изображение 2 из 2
      • Remove the SATA cable adapter from the hard drive.
      Спросите у FixBot
Заключение
Clay Eickemeyer
Участник с: 09/19/22
106 869 Репутация
Автор 472 руководств
Команда
Guide Team Участник Guide Team
Staff
10 членов
Автор 61 154 руководств
2 Комментарии к руководству
Would you mind to spill the name/part number of the flex SATA cable for the HDD/SSD? For my flex SATA is gone and it's hard to find the replacement for my Razer Blade Base 2018, Thanks for advance
Isai Isai - Ответить Поделиться
Is it a SATA or NVMe slot? I want to install a 2.5" NVMe SSD.
Jerry Li - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 16
За последние 30 дней: 43
За всё время: 1,610
