Samsung Galaxy A51 Screen Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy A51 Screen Replacement, Samsung Galaxy A51 SIM Tray Removal: шаг 1, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement, Samsung Galaxy A51 SIM Tray Removal: шаг 1, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement, Samsung Galaxy A51 SIM Tray Removal: шаг 1, изображение 3 из 3
    • Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
  2. Samsung Galaxy A51 Screen Replacement, Back Cover: шаг 2, изображение 1 из 1
    • Before beginning this procedure, completely power off your phone.
    • Prepare an iOpener and apply it to the back cover to soften the adhesive.
    • The adhesive of the Samsung Galaxy A51 is very strong. You can use a hair dryer or a heat gun if you aren't able to open the device with the iOpener.
    • Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  3. Samsung Galaxy A51 Screen Replacement: шаг 3, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 3, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 3, изображение 3 из 3
    • Insert the tip of an opening pick between the frame and the back cover at the bottom of the phone near the USB-C port.
    • If you can't get between the back cover and midframe with your opening pick, you can use a suction handle or strong tape to pull up the back cover to create a gap.
    • Slide the opening pick to the bottom right corner and leave it there.
  4. Samsung Galaxy A51 Screen Replacement: шаг 4, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 4, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 4, изображение 3 из 3
    • Insert a second opening pick and slide it from the bottom right corner to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Samsung Galaxy A51 Screen Replacement: шаг 5, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 5, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 5, изображение 3 из 3
    • Insert a third opening pick under the bottom left corner of the back cover.
    • If you have any trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick along the left edge of the phone.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A51 Screen Replacement: шаг 6, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 6, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 6, изображение 3 из 3
    • Insert a fourth opening pick under the top left corner of the back cover near the camera.
    • Slide the tip of the opening pick along the top edge of the phone to the right corner to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A51 Screen Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 7, изображение 3 из 3
    • With opening picks in all four corners, insert a fifth and final opening pick under the top right corner of the back cover.
    • Slide the tip of the opening pick along the right edge of the phone to the bottom right corner to cut the remaining adhesive.
  8. Samsung Galaxy A51 Screen Replacement: шаг 8, изображение 1 из 1
    • Remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Samsung Galaxy A51 Screen Replacement, Midframe: шаг 9, изображение 1 из 1
    • Remove the thirteen 3 mm Phillips #00 screws securing the midframe.
  10. Samsung Galaxy A51 Screen Replacement: шаг 10, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 10, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 10, изображение 3 из 3
    • The midframe is held in place by plastic clips.
    • Insert an opening pick between the midframe and front panel assembly on the bottom of the phone near the charge port.
    • Slide the opening pick to the left bottom corner to release the plastic clips.
    • Slide the opening pick to the bottom right corner to release the rest of the bottom plastic clips.
  11. Samsung Galaxy A51 Screen Replacement: шаг 11, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 11, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 11, изображение 3 из 3
    • Continue sliding the opening pick on the right side of your phone until all plastic clips on the right side are released.
  12. Samsung Galaxy A51 Screen Replacement: шаг 12, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 12, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 12, изображение 3 из 3
    • Slide the opening pick along the top edge to release the top plastic clips.
  13. Samsung Galaxy A51 Screen Replacement: шаг 13, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 13, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 13, изображение 3 из 3
    • Slide the opening pick from the top left corner to the bottom left corner to release the left side's plastic clips.
  14. Samsung Galaxy A51 Screen Replacement: шаг 14, изображение 1 из 1
    • Remove the midframe.
  15. Samsung Galaxy A51 Screen Replacement, Battery Disconnect: шаг 15, изображение 1 из 2 Samsung Galaxy A51 Screen Replacement, Battery Disconnect: шаг 15, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the battery by prying the connector straight up from its socket.
  16. Samsung Galaxy A51 Screen Replacement, Screen: шаг 16, изображение 1 из 2 Samsung Galaxy A51 Screen Replacement, Screen: шаг 16, изображение 2 из 2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable on the bottom of the phone.
  17. Samsung Galaxy A51 Screen Replacement: шаг 17, изображение 1 из 1
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough to cut the adhesive. Follow the iOpener instructions to avoid overheating.
  18. Samsung Galaxy A51 Screen Replacement: шаг 18, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 18, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 18, изображение 3 из 3
    • Once the screen is warm to the touch, apply a suction cup to the upper edge of the phone.
    • If the screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Insert an opening pick in the gap and start to cut the adhesive by sliding it to the top right corner.
  19. Samsung Galaxy A51 Screen Replacement: шаг 19, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 19, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 19, изображение 3 из 3
    • Insert a second opening pick and slide it to the top left corner.
  20. Samsung Galaxy A51 Screen Replacement: шаг 20, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 20, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 20, изображение 3 из 3
    • Insert a third opening pick and slide it along the left edge to cut the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  21. Samsung Galaxy A51 Screen Replacement: шаг 21, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 21, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 21, изображение 3 из 3
    • Insert a fourth opening pick and slide it from the bottom left corner to the bottom right corner.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  22. Samsung Galaxy A51 Screen Replacement: шаг 22, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 22, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 22, изображение 3 из 3
    • Insert a fifth opening pick and slide it along the left edge of the phone to cut the remaining adhesive.
  23. Samsung Galaxy A51 Screen Replacement: шаг 23, изображение 1 из 2 Samsung Galaxy A51 Screen Replacement: шаг 23, изображение 2 из 2
    • Reapply a heated iOpener to the screen to loosen the adhesive underneath.
    • As you wait, take note of the rectangular-shaped adhesive placed underneath the screen.
  24. Samsung Galaxy A51 Screen Replacement: шаг 24, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 24, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 24, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • Insert a plastic card on the left edge into the gap between display and the phone assembly.
    • Press the plastic card in and slide it back and forth until you cut through the entire adhesive.
    • Once you are sure you cut through the adhesive, remove the four opening picks from the corners.
    • Do not remove the screen completely yet. The display cable is still threaded through the frame.
  25. Samsung Galaxy A51 Screen Replacement: шаг 25, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 25, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 25, изображение 3 из 3
    • Carefully thread the display cable through the frame.
  26. Samsung Galaxy A51 Screen Replacement: шаг 26, изображение 1 из 3 Samsung Galaxy A51 Screen Replacement: шаг 26, изображение 2 из 3 Samsung Galaxy A51 Screen Replacement: шаг 26, изображение 3 из 3
    • Remove the screen.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
57 участников успешно повторили данное руководство.
Adriana Zwink
Участник с: 12/18/19
48 265 Репутация
Автор 167 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
13 Комментариев
Can we get a video for this soon? Thanks.
hello3459 - Ответить
Fingerprint scanner is disabled when original screen is replaced
JustAThought - Ответить
You need to buy the right replacement screen like the one that supports fingerprint like amoled
Jeremy Kisluk -
Attention, Fingerprint makes some trouble after replaceing the display
Fernseh Hartung - Ответить
I see that users have posted about the Fingerprint Scanner causing issues. “…disabled when original screen is replaced” or “… some trouble after replacing…” Are these issues that since have been resolved? Scanner can be re-enabled or disabled and re-enabled to bypass the “issues”?
Obfuscated_Hate - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 54
За последние 7 дней: 403
За последние 30 дней: 1,844
За всё время: 120,909
