Введение
Use this guide to replace the heat sink in your Galaxy Book Pro 360 15" laptop.
Before you begin, refer to the Samsung PC Repair Guide for safety information.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Note: Some photos in this guide may contain slight visual discrepancies, but they won't affect the guide procedure.
Выберете то, что вам нужно
Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
Insert an opening pick between the rear case and the rubber foot.
Pry up with the pick and dislodge the foot from the rear case.
Use tweezers or your fingers to remove the rubber foot.
Repeat this process on the remaining rubber feet.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick along the bottom edge to release the clips securing the rear case.
Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
Lift the rear case up and away from the laptop and remove it.
Use tweezers or your fingers to peel up and remove the tape covering the battery connector.
Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
Gently pry up and disconnect the battery connector from its socket.
Use a Phillips screwdriver to remove the screws securing the heat sink:
Two 3.5 mm screws
Four 3.1 mm screws
Инструмент, используемый на этом этапе:Microfiber Cleaning Cloths$3.99
Scrape off the old thermal paste from the processor and heat sink with a spudger.
Remove any remaining thermal paste with isopropyl alcohol and a coffee filter or microfiber cloth.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
