Введение
This is a prerequisite guide! This guide is part of another procedure and is not meant to be used alone.
This prereq guide exists solely to support the existing in-house guides that were written before the official parts existed. The public version of the USB-C guide has a slightly different procedure, and supports the official part.
This guide demonstrates how to remove or replace the USB-C port and daughterboard in the Galaxy S20.
You'll need replacement adhesive in order to complete this repair.
Выберете то, что вам нужно
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
Slide the pick back and forth along the bottom edge to slice through the adhesive.
Leave your opening pick in the seam to prevent the adhesive from resealing.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
Leave your pick under the left edge of the glass near the top left corner to prevent the adhesive from resealing.
Apply a heated iOpener to the right edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Gradually slide the pick from the right edge of the device around the top right corner.
Continue slicing along the top edge all the way to the top left corner to fully separate the back cover adhesive.
Инструмент, используемый на этом этапе:Tweezers$4.99
Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using Samsung custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the motherboard bracket.
Gently peel the wireless charging coil away from the device.
Remove the wireless charging coil.
Use a spudger to pry up and disconnect the battery connector.
Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
Use a spudger to pry up and disconnect the main and auxiliary flex cables from the daughterboard near the bottom of the device.
Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard.
Gently peel up and remove the main and auxiliary flex cables.
Use a Phillips #00 screwdriver to remove the three 3.4 mm-long screws securing the USB-C port and daughterboard.
3 участников успешно повторили данное руководство.
