How to Replace the Back Cover Adhesive (Frame First)
Выберете то, что вам нужно
  1. How to Replace the Back Cover Adhesive (Frame First), Remove the remaining adhesive: шаг 1, изображение 1 из 1
    • If you're re-using your frame, remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • Repeat the same procedure for any remaining adhesive on the back cover.
    Спросите у FixBot
    Добавить комментарий
  2. How to Replace the Back Cover Adhesive (Frame First): шаг 2, изображение 1 из 1
    • Before removing any liners, position the adhesive strip with the clear liner facing down over the frame to find the proper orientation.
    • You can use the rear camera cutout as a reference point.
    • If the adhesive matches the back cover instead of the frame, follow this cover-first adhesive guide.
    Спросите у FixBot
  3. How to Replace the Back Cover Adhesive (Frame First), Expose the adhesive: шаг 3, изображение 1 из 2 How to Replace the Back Cover Adhesive (Frame First), Expose the adhesive: шаг 3, изображение 2 из 2
    • Peel the clear liner off of the adhesive strip to expose the adhesive.
    Спросите у FixBot
  4. How to Replace the Back Cover Adhesive (Frame First), Align the adhesive: шаг 4, изображение 1 из 3 How to Replace the Back Cover Adhesive (Frame First), Align the adhesive: шаг 4, изображение 2 из 3 How to Replace the Back Cover Adhesive (Frame First), Align the adhesive: шаг 4, изображение 3 из 3
    • Be very careful with this step, as misaligning the adhesive can cause it to peek out of the phone during reassembly, leading to an improper seal.
    • The adhesive is very sticky! Be careful with alignment, as you won't be able to reposition the adhesive once it sticks.
    • Carefully align the sticky side of the adhesive over the edges of the frame.
    • You can use the screw holes to help line up the adhesive.
    • Press down on the perimeter of the adhesive strip to bond it to the frame.
    Спросите у FixBot
  5. How to Replace the Back Cover Adhesive (Frame First): шаг 5, изображение 1 из 2 How to Replace the Back Cover Adhesive (Frame First): шаг 5, изображение 2 из 2
    • Peel off the colored liner from the adhesive strip to expose the opposite side of the adhesive.
    Спросите у FixBot
  6. How to Replace the Back Cover Adhesive (Frame First): шаг 6, изображение 1 из 2 How to Replace the Back Cover Adhesive (Frame First): шаг 6, изображение 2 из 2
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Align the back cover with its original position on the frame.
    • Press down on the perimeter of the adhesive to bond the adhesive to the back cover.
    • To ensure a good seal, apply constant pressure to the back cover with a flat, heavy object. A hefty book works well.
    • If a substantial gap remains, try squeezing the gap with your fingers but don't force it. Pry the back cover off and check for any surface irregularities, such as unseated connectors or loose and jutting screws.
    Спросите у FixBot
Финишная прямая
22 человек успешно провели ремонт по этому руководству.
Alex Diaz-Kokaisl
Участник с: 01/16/22
244 886 Репутация
Автор 1 203 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 30 155 руководств
3 Комментарии к руководству
Many thanks for the instructions.
Note:
Unfortunately, removing the old adhesive is a laborious process that requires a lot of effort. (Samsung Note 20 Ultra 5G with adhesive film that has already completely dissolved on its own!)
Absolutely necessary - in addition to patience: ISOPROPANOL (e.g. https://amzn.eu/d/7ZIPJCJ) - this dissolves all adhesives (be careful)!
Carefully scrape off the adhesive layers with a plastic spatula - plus cotton swabs plus cosmetic tissues (do not leave lint) then laboriously remove the adhesive residue.
ISOPROPANOL 99.9% does not damage electronics, i.e. can therefore be used for cleaning without hesitation.
Woody Woodpecker - Ответить Поделиться
Unfortunately, though your repair instructions have separate links for a preglued template or glue tape, the links both lead to the template instructions. There is nothing on glue tape for sealing your phone. Could you please add instructions?
Joan - Ответить Поделиться
The removal of old glue is indeed laborious and very time consuming. Because the back cover is made of glass, you cannot use too much pressure with a spudger to roll the old glue up. I tried heat but, again, with a glass cover, this is also risky, as the back cover paint is inclined to lift off with the glue. The only safe method I found was to trail a line of 99% IPA, let it soak for up to ten seconds and then using a flat ended spudger to roll the glue from the edges inwards. More IPA then from inwards to the edge to meet the glue in the middle. More IPA then roll the glue along until you have a ball you can remove. Manage your expectations because this will take a long time.
S Duggan - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 29
За последние 7 дней: 197
За последние 30 дней: 1,042
За всё время: 25,694
