Samsung Galaxy S21 Battery Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S21 Battery Replacement, Heat the bottom edge: шаг 1, изображение 1 из 1
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display, internal battery, and plastic back cover are both susceptible to heat damage.
  2. Samsung Galaxy S21 Battery Replacement, Separate the bottom adhesive: шаг 2, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Separate the bottom adhesive: шаг 2, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Separate the bottom adhesive: шаг 2, изображение 3 из 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Only insert the pick up to 5 mm, as you may damage internal components if you go further.
  3. Samsung Galaxy S21 Battery Replacement, Slice the bottom adhesive: шаг 3, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Slice the bottom adhesive: шаг 3, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Slice the bottom adhesive: шаг 3, изображение 3 из 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Samsung Galaxy S21 Battery Replacement, Heat the left edge: шаг 4, изображение 1 из 1
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  5. Samsung Galaxy S21 Battery Replacement, Separate the left adhesive: шаг 5, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Separate the left adhesive: шаг 5, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Separate the left adhesive: шаг 5, изображение 3 из 3
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
  6. Samsung Galaxy S21 Battery Replacement: шаг 6, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement: шаг 6, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement: шаг 6, изображение 3 из 3
    • Slide an opening pick along the left edge towards the bottom left corner to cut the adhesive.
    • Don't cut past where the camera shell meets the back cover, as you risk cracking the plastic.
  7. Samsung Galaxy S21 Battery Replacement, Heat the right edge: шаг 7, изображение 1 из 1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  8. Samsung Galaxy S21 Battery Replacement, Separate the right adhesive: шаг 8, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Separate the right adhesive: шаг 8, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Separate the right adhesive: шаг 8, изображение 3 из 3
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Only insert the pick up to 3 mm, as you may damage the secondary interconnect cable, which runs parallel to the right edge.
  9. Samsung Galaxy S21 Battery Replacement: шаг 9, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement: шаг 9, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement: шаг 9, изображение 3 из 3
    • Slide an opening pick back and forth along the back cover's right edge to cut the adhesive.
  10. Samsung Galaxy S21 Battery Replacement, Separate the corner adhesive: шаг 10, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Separate the corner adhesive: шаг 10, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Separate the corner adhesive: шаг 10, изображение 3 из 3
    • Rotate the right-edge opening pick around the top-right corner of the phone.
    • This procedure can be applied to each corner, except the top-left where the rear-facing camera is located.
  11. Samsung Galaxy S21 Battery Replacement, Reposition the opening picks: шаг 11, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Reposition the opening picks: шаг 11, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Reposition the opening picks: шаг 11, изображение 3 из 3
    • Slide the top-most opening pick as close to the camera shell as possible.
    • Repeat for the left-edge pick.
  12. Samsung Galaxy S21 Battery Replacement, Heat the camera shell: шаг 12, изображение 1 из 1
    • Heat an iOpener and apply it to the camera shell for two minutes.
  13. Samsung Galaxy S21 Battery Replacement, Separate the camera shell adhesive: шаг 13, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Separate the camera shell adhesive: шаг 13, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Separate the camera shell adhesive: шаг 13, изображение 3 из 3
    • Rotate the back cover counterclockwise to create a gap between the camera shell and the frame.
    • Only insert the pick up to 5 mm to avoid scratching the camera.
    • Insert an opening pick in the gap.
    • If this method doesn't work, move to the next step for an alternative method; otherwise, skip the next step.
  14. Samsung Galaxy S21 Battery Replacement, Separate the camera shell adhesive (alternate method): шаг 14, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Separate the camera shell adhesive (alternate method): шаг 14, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Separate the camera shell adhesive (alternate method): шаг 14, изображение 3 из 3
    • Gently slide the two picks toward the camera shell so they are under the corners of the back cover adjacent to the camera shell.
    • Move the picks back and forth along the bridge between the back cover and the camera shell until you create a gap between the camera shell and the frame.
    • Be careful with this method, as you risk cracking the plastic back cover.
  15. Samsung Galaxy S21 Battery Replacement: шаг 15, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement: шаг 15, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement: шаг 15, изображение 3 из 3
    • Slide an opening pick between the camera shell and the frame to cut the adhesive.
    • There's a significant amount of adhesive securing the frame to the camera shell, so multiple rounds of heating may be needed.
  16. Samsung Galaxy S21 Battery Replacement: шаг 16, изображение 1 из 2 Samsung Galaxy S21 Battery Replacement: шаг 16, изображение 2 из 2
    • There's additional adhesive to the right of the camera that you need to cut through.
    • There's a plate on the back cover surrounding the phone's flash that the pick can get stuck on:
    • Angle the pick downward to avoid any damage.
  17. Samsung Galaxy S21 Battery Replacement: шаг 17, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement: шаг 17, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement: шаг 17, изображение 3 из 3
    • Line up the opening pick's tip with your phone's flash
    • Insert the pick slowly, making sure to avoid the flash's plate.
    • The plate's resistance can feel similar to adhesive. Angle the pick downward to keep the pick from sliding into the plate.
    • Slice the adhesive to the right of the camera.
  18. Samsung Galaxy S21 Battery Replacement, Remove the back cover: шаг 18, изображение 1 из 2 Samsung Galaxy S21 Battery Replacement, Remove the back cover: шаг 18, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone until the back cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  19. Samsung Galaxy S21 Battery Replacement, Unfasten the motherboard bracket: шаг 19, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the five 4 mm-long screws securing the motherboard bracket to the frame.
    • Throughout this repair, keep track of each screw, and make sure it goes back exactly where it came from.
  20. Samsung Galaxy S21 Battery Replacement, Unclip the motherboard bracket: шаг 20, изображение 1 из 2 Samsung Galaxy S21 Battery Replacement, Unclip the motherboard bracket: шаг 20, изображение 2 из 2
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the frame.
    • Do not completely remove the bracket yet, as it's still attached to the wireless charging coil.
  21. Samsung Galaxy S21 Battery Replacement, Disconnect the battery: шаг 21, изображение 1 из 2 Samsung Galaxy S21 Battery Replacement, Disconnect the battery: шаг 21, изображение 2 из 2
    • While using tweezers, or your fingers, to hold the motherboard bracket out of the way, use a spudger to pry up the battery press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. Samsung Galaxy S21 Battery Replacement, Disconnect the wireless charging coil: шаг 22, изображение 1 из 2 Samsung Galaxy S21 Battery Replacement, Disconnect the wireless charging coil: шаг 22, изображение 2 из 2
    • While still holding the motherboard bracket out of the way, use a spudger to pry up and disconnect the wireless charging coil's press connector.
  23. Samsung Galaxy S21 Battery Replacement, Remove the wireless charging coil: шаг 23, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Remove the wireless charging coil: шаг 23, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Remove the wireless charging coil: шаг 23, изображение 3 из 3
    • The wireless charging coil is secured to the phone with light adhesive.
    • Use your fingers to gently peel the wireless charging coil away from the phone.
    • During reassembly, refasten the motherboard bracket screws first to properly align the charging coil into place, then firmly press the rest of the coil down to adhere it.
  24. Samsung Galaxy S21 Battery Replacement, Unfasten the loudspeaker: шаг 24, изображение 1 из 1
    • Use a Phillips screwdriver to remove the six 4 mm screws securing the loudspeaker to the frame.
  25. Samsung Galaxy S21 Battery Replacement, Remove the loudspeaker: шаг 25, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Remove the loudspeaker: шаг 25, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Remove the loudspeaker: шаг 25, изображение 3 из 3
    • Insert the point of a spudger into the notch in the top-left corner of the loudspeaker and pry up to release the clips holding it in place.
    • Remove the loudspeaker.
  26. Samsung Galaxy S21 Battery Replacement, Disconnect the primary interconnect cable: шаг 26, изображение 1 из 2 Samsung Galaxy S21 Battery Replacement, Disconnect the primary interconnect cable: шаг 26, изображение 2 из 2
    • Use the flat end of a spudger to pry up and disconnect the primary interconnect cable's press connector.
  27. Samsung Galaxy S21 Battery Replacement, Disconnect the secondary interconnect cable: шаг 27, изображение 1 из 2 Samsung Galaxy S21 Battery Replacement, Disconnect the secondary interconnect cable: шаг 27, изображение 2 из 2
    • Use the flat end of a spudger to pry up and disconnect the secondary interconnect cable's press connector.
  28. Samsung Galaxy S21 Battery Replacement, Disconnect the secondary/primary interconnect cables: шаг 28, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Disconnect the secondary/primary interconnect cables: шаг 28, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Disconnect the secondary/primary interconnect cables: шаг 28, изображение 3 из 3
    • Use the flat end of a spudger to pry up on the secondary interconnect cable's press connector.
    • Repeat for the primary interconnect cable's press connector.
  29. Samsung Galaxy S21 Battery Replacement, Remove the secondary/primary interconnect cables: шаг 29, изображение 1 из 2 Samsung Galaxy S21 Battery Replacement, Remove the secondary/primary interconnect cables: шаг 29, изображение 2 из 2
    • Use tweezers, or your fingers, to remove the secondary and primary interconnect cables.
  30. Samsung Galaxy S21 Battery Replacement, Disconnect the display cable: шаг 30, изображение 1 из 2 Samsung Galaxy S21 Battery Replacement, Disconnect the display cable: шаг 30, изображение 2 из 2
    • Use a spudger to pry up and disconnect the display cable's bottom press connector.
  31. Samsung Galaxy S21 Battery Replacement: шаг 31, изображение 1 из 2 Samsung Galaxy S21 Battery Replacement: шаг 31, изображение 2 из 2
    • Use a spudger to pry up and disconnect the display cable's top press connector.
  32. Samsung Galaxy S21 Battery Replacement, Remove the display cable: шаг 32, изображение 1 из 1
    • Use tweezers, or your fingers, to remove the display cable.
  33. Samsung Galaxy S21 Battery Replacement, Apply isopropyl alcohol: шаг 33, изображение 1 из 2 Samsung Galaxy S21 Battery Replacement, Apply isopropyl alcohol: шаг 33, изображение 2 из 2
    • Take care not to puncture or bend the battery during the removal procedure—a punctured or bent battery may leak dangerous chemicals or cause a thermal event. In case you're struggling to pull up the battery, apply more isopropyl alcohol and try again.
    • Apply 1-2 drops of high concentration (over 90%) isopropyl alcohol to the gaps surrounding the battery's perimeter.
    • Only apply a few drops initially and apply more if necessary; too much isopropyl alcohol might overflow onto the motherboard and daughterboard or damage the display
  34. Samsung Galaxy S21 Battery Replacement, Insert an opening pick: шаг 34, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Insert an opening pick: шаг 34, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Insert an opening pick: шаг 34, изображение 3 из 3
    • Apply a suction cup to the battery, as close to the center of the right edge as possible.
    • Insert an opening pick into the edge with the widest gap between the frame and the battery.
    • Rotate the opening pick to insert its long edge into the gap.
  35. Samsung Galaxy S21 Battery Replacement, Separate the battery's adhesive: шаг 35, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Separate the battery's adhesive: шаг 35, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Separate the battery's adhesive: шаг 35, изображение 3 из 3
    • Pull up on the suction cup with strong, steady force and pry up with the opening pick to separate the battery from the frame.
    • If you're struggling to pull up the battery with your suction handle, apply 1-2 more drops of isopropyl alcohol.
  36. Samsung Galaxy S21 Battery Replacement, Remove the battery: шаг 36, изображение 1 из 3 Samsung Galaxy S21 Battery Replacement, Remove the battery: шаг 36, изображение 2 из 3 Samsung Galaxy S21 Battery Replacement, Remove the battery: шаг 36, изображение 3 из 3
    • Remove the battery, making sure to peel off any remaining adhesive.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    • Temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it's seated.
Заключение
Follow this guide to perform a battery cycle reset, and calibrate your newly-installed battery.
37 человек успешно провели ремонт по этому руководству.
Alex Diaz-Kokaisl
Участник с: 01/16/22
161 942 Репутация
Автор 769 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 410 руководств
11 Комментариев
Will it void my warranty
BakaDolev - Ответить
Yes, unfortunately the warranty will be voided if you "tamper" with any of the components.
Alex Diaz-Kokaisl -
Just a note to the last step regarding iso. Be careful not applying too much iso - it will run down to the display via the hole in the back.
Adam Skou Ohana - Ответить
The glue is a pain but I wasn't nearly as careful on the bottom part as the guide suggested and was able to get it off just fine. I also didn't bother to remove the old glue and it holds well enough
Josh Oxborrow - Ответить
will my waterproofness go away
Rzgar67 - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 138
За последние 7 дней: 908
За последние 30 дней: 3,587
За всё время: 121,921
