Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the SIM card tray: шаг 1, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the SIM card tray: шаг 1, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the SIM card tray: шаг 1, изображение 3 из 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  2. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Heat the right edge: шаг 2, изображение 1 из 1
    • Let your phone's battery drain to below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Adhesive information: шаг 3, изображение 1 из 2 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Adhesive information: шаг 3, изображение 2 из 2
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  4. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Insert an opening pick: шаг 4, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Insert an opening pick: шаг 4, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Insert an opening pick: шаг 4, изображение 3 из 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  5. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the right adhesive: шаг 5, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the right adhesive: шаг 5, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the right adhesive: шаг 5, изображение 3 из 3
    • Slide the pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick inserted near the bottom of the right edge to prevent the adhesive from resealing.
  6. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Heat the bottom edge: шаг 6, изображение 1 из 1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  7. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: шаг 7, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: шаг 7, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: шаг 7, изображение 3 из 3
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while slicing around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  8. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the bottom adhesive: шаг 8, изображение 1 из 2 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the bottom adhesive: шаг 8, изображение 2 из 2
    • Slide your opening pick to the bottom left corner to slice the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  9. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Heat the left edge: шаг 9, изображение 1 из 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  10. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: шаг 10, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: шаг 10, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: шаг 10, изображение 3 из 3
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  11. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the left adhesive: шаг 11, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the left adhesive: шаг 11, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the left adhesive: шаг 11, изображение 3 из 3
    • Slide your opening pick along the left edge to slice the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  12. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Heat the top edge: шаг 12, изображение 1 из 1
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  13. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: шаг 13, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: шаг 13, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: шаг 13, изображение 3 из 3
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  14. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the top adhesive: шаг 14, изображение 1 из 2 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the top adhesive: шаг 14, изображение 2 из 2
    • Slide the pick to the top left corner to slice the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  15. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: шаг 15, изображение 1 из 2 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Separate the corner adhesive: шаг 15, изображение 2 из 2
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Insert an opening pick in the gap at the top left edge.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  16. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the remaining adhesive: шаг 16, изображение 1 из 2 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the remaining adhesive: шаг 16, изображение 2 из 2
    • Slide the pick toward the bottom camera to slice through the remaining adhesive, stopping before you reach the power button.
  17. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the back cover: шаг 17, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the back cover: шаг 17, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the back cover: шаг 17, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  18. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the adhesive: шаг 18, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the adhesive: шаг 18, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Slice the adhesive: шаг 18, изображение 3 из 3
    • The wireless charging coil is lightly adhered to the battery.
    • Be careful not to strain or tear the display interconnect cable under the right side of the charging coil.
    • Insert an opening pick between the right edge of the wireless charging coil and the battery.
    • Slide the pick along the right edge to separate the adhesive.
  19. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the NFC antenna and charging coil: шаг 19, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the NFC antenna and charging coil: шаг 19, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the NFC antenna and charging coil: шаг 19, изображение 3 из 3
    • Use the pointed end of a spudger to pry and disconnect the NFC antenna press connector from the motherboard.
    • Repeat for the wireless charging coil press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  20. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Unfasten the NFC antenna and charging coil: шаг 20, изображение 1 из 1
    • Use your Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
  21. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Unfasten the loudspeaker: шаг 21, изображение 1 из 1
    • Use your Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
  22. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Unclip the loudspeaker: шаг 22, изображение 1 из 2 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Unclip the loudspeaker: шаг 22, изображение 2 из 2
    • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  23. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: шаг 23, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: шаг 23, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: шаг 23, изображение 3 из 3
    • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
    • The wireless charging coil holds these parts together.
  24. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the battery: шаг 24, изображение 1 из 2 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the battery: шаг 24, изображение 2 из 2
    • Use the pointed end of your spudger to pry up and disconnect the battery press connector.
  25. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: шаг 25, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: шаг 25, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: шаг 25, изображение 3 из 3
    • Use the pointed end of your spudger to pry up and disconnect the primary interconnect cable's press connector from the motherboard.
    • Repeat for the secondary interconnect cable.
  26. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement: шаг 26, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement: шаг 26, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement: шаг 26, изображение 3 из 3
    • Use the pointed end of your spudger to pry up and disconnect the primary interconnect cable's press connector from the charging board.
  27. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the interconnect cables: шаг 27, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the interconnect cables: шаг 27, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the interconnect cables: шаг 27, изображение 3 из 3
    • Grab and remove the interconnect cables from the frame.
  28. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Unfasten the charging board: шаг 28, изображение 1 из 1
    • Use your Phillips screwdriver to remove the three 3.5 mm-long screws securing the charging board.
  29. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Pry up the charging board: шаг 29, изображение 1 из 2 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Pry up the charging board: шаг 29, изображение 2 из 2
    • Insert the pointed end of your spudger under the charging board opposite the USB-C port.
    • Pry the charging board up from its recess until you can grab it with your fingers.
  30. Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the charging board: шаг 30, изображение 1 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the charging board: шаг 30, изображение 2 из 3 Samsung Galaxy S22 Ultra USB-C Port and Charging Board Replacement, Remove the charging board: шаг 30, изображение 3 из 3
    • Grip the charging board by its corners and slide it out of its recess in the frame.
    • Remove the charging board.
    • During reassembly, reinsert the charging board at a downward angle to guide the USB-C port into its recess.
Заключение
12 человек успешно провели ремонт по этому руководству.
Clay Eickemeyer
Участник с: 09/19/22
80 983 Репутация
Автор 455 руководств
Команду
Guide Team Участник Guide Team
Staff
9 членов
Автор 11 332 руководств
9 Комментариев
Do you have access to a Samsung S10 SM-G973U USB-C port charger?
FULLTILT007 - Ответить
Hi! Would you be able to clarify which part you're asking about? We do sell that specific charging port, here. This replacement involves micro-soldering, and you would start at the S10 motherboard removal. If you're looking for an easier part to replace, such as the guide we are on now, we don't sell an equivalent kit for the S10.
Clay Eickemeyer -
After finishing this in about an hour, I would definitely recommend a heat gun over the Iopener. I spent around 15 minutes trying to pry the case open with the Iopener and found that it does get hot enough, but it doesn't seem to put that heat into the phone very well. I had the back cover off in around 5 minutes with a heat gun. Second, I would recommend buying the Ifixit precut adhesive seal kit, it is a few dollars, and you can be sure that you maintain the water proof seal on the phone. I did not need two of the seals, but I would have felt more secure if I had a backup in case I misaligned it and needed to start over.
Marcus Brown - Ответить
I'm assuming this will also replace whatever module detects moisture?
Ian S - Ответить
Most smartphones have multiple water damage indicators all around the device in the form of small non-electronic pads that discolor after exposure to water. If you're referring to an issue where persistent "Moisture Detected" type warnings are preventing you from charging your phone, then multiple causes, both software and hardware, could be factors. If, after troubleshooting, you rule out any software issues, then this repair is likely to fix a hardware or corrosion issue in your port. Good luck!
Clay Eickemeyer -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 28
За последние 7 дней: 151
За последние 30 дней: 659
За всё время: 30,870
