Samsung Galaxy Watch4 Classic Display Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Watch4 Classic Display Replacement, Power down your watch: шаг 1, изображение 1 из 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4 Classic Display Replacement, Unscrew the back cover: шаг 2, изображение 1 из 1
    • Use a Tri-point Y000 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
    • Lay the watch face down.
    • Carefully swing open the back cover by folding it to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
    • Use the pointed end of a spudger to disconnect the hall sensor-, the display-, and the crown button flex cable.
  3. Samsung Galaxy Watch4 Classic Display Replacement, Unscrew the motherboard: шаг 6, изображение 1 из 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  4. Samsung Galaxy Watch4 Classic Display Replacement, Remove the motherboard: шаг 7, изображение 1 из 3 Samsung Galaxy Watch4 Classic Display Replacement, Remove the motherboard: шаг 7, изображение 2 из 3 Samsung Galaxy Watch4 Classic Display Replacement, Remove the motherboard: шаг 7, изображение 3 из 3
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
    • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
    • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
    • Thread the display flex cable through the opening in the core assembly.
    • Remove the core assembly.
  5. Samsung Galaxy Watch4 Classic Display Replacement, Heat the display: шаг 9, изображение 1 из 1
    • Heat an iOpener and apply it to the display for two minutes to loosen the adhesive.
    • If your display is cracked, keep glass shards contained by applying a strip of tape over the glass.
    • Use your finger to steadily push the display down through the watch's metal housing to separate the display from the frame.
    • Remove the display.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
4 участников успешно повторили данное руководство.
Adriana Zwink
Участник с: 12/18/19
48 623 Репутация
Автор 167 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 17 288 руководств
Один комментарий
Where can I order the screen?
Scott Snyder - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 73
За последние 30 дней: 313
За всё время: 11,013
