Введение
Use this guide to replace the motherboard in your Samsung Galaxy Watch5.
Выберете то, что вам нужно
Take your watch off the charger and power it down.
Remove the watch band.
Use a Tri-point Y000 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
Insert an opening tool into the seam between the back cover and the metal housing.
Twist the opening tool to loosen the gasket and create a gap.
Lay the watch screen-side down.
Carefully swing open the back cover at the gap you just created.
Use a spudger to disconnect the sensor flex cable from the motherboard by prying the press connector straight up from its socket.
Remove the back cover.
Make sure the rubber gasket (marked in red) is undamaged. If damaged, replace it with a new one to maintain water resistance.
Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
Use a spudger to disconnect the button flex cable by prying the connector straight up from its socket.
Use a Phillips screwdriver to remove the single 4.4 mm–long screw securing the motherboard.
If possible, turn on your device and test your repair before resealing.
Еще один человек закончил это руководство.
