Введение
This guide shows how to remove and replace the door sensors in your Samsung RF28R7201SG refrigerator.
The Samsung fridge uses a magnetic reed switch for each French door. If these sensors fail, the refrigerator will think a door is always open or closed.
Выберете то, что вам нужно
Use a Phillips screwdriver to remove the three 18.5 mm-long screws securing the hinge cover on the top of the refrigerator.
Lift the edges of the hinge cover to loosen it from the refrigerator.
Flip the hinge cover over to access the cables underneath.
Use your fingers to squeeze and disconnect the blue wire connector.
Use your fingers to squeeze and disconnect the white wire connector.
The left door sensor
The left door sensor connector
The right door sensor
The right door sensor connector
Use your fingers to squeeze and disconnect the sensor cable connector.
Use a spudger or a flathead screwdriver to pry the sensor out of its retaining clips.
Repair didn’t go as planned? Ask our Answers community for help.
