Введение
This guide shows how to remove and replace the freezer evaporator fan or circulation fan in your Samsung RF28R7201SG refrigerator.
The Samsung fridge has two evaporator fans, and this guide is for the fan in the freezer compartment. For the refrigerator evaporator fan, follow this guide instead.
The evaporator fan circulates cold air from the evaporator coils into the freezer compartment. If your freezer isn't cooling sufficiently or evenly (the back of the compartment gets much colder), you may have a faulty evaporator fan.
Выберете то, что вам нужно
Use a flathead screwdriver to press in the plastic tab near the inner end of the drawer rail.
As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
Repeat the rail unlock procedure on the other drawer rail.
Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
Remove the freezer drawer.
Push the geared torsion bar until it rests at the very end of the rails.
Align the drawer rails to the refrigerator wall guides.
Close the freezer drawer until the rails lock back in place.
Use a Phillips screwdriver to remove the two 16.2 mm-long screws securing the freezer evaporator cover.
Use your hands to lift the bottom edge of the evaporator cover up to release the lower plastic tabs.
Swing the evaporator cover upwards to access the connected wires behind it.
Use your fingers to squeeze and disconnect the fan cable connector from the back wall of the freezer.
Guide the fan cable from the evaporator cover clips.
Use a Phillips screwdriver to remove the four 18.3 mm-long screws securing the back panel to the evaporator cover.
Use your fingers to pry and release the clips along the short edge of the evaporator cover.
Use a Phillips screwdriver to remove the three 14.2 mm-long screws securing the fan to the evaporator cover.
Repair didn’t go as planned? Ask our Answers community for help.
