Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement
Выберете то, что вам нужно
  1. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Unplug your refrigerator: шаг 1, изображение 1 из 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Open the freezer drawer: шаг 2, изображение 1 из 1
    • Slide the freezer drawer fully open.
  3. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer bins: шаг 3, изображение 1 из 1
    • Lift and remove all the freezer bins from the drawer.
    • You should be left with a freezer door attached by two rails.
  4. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: шаг 4, изображение 1 из 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: шаг 4, изображение 2 из 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: шаг 4, изображение 3 из 3
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 5, изображение 1 из 2 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 5, изображение 2 из 2
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
  6. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer compartment evaporator cover: шаг 6, изображение 1 из 1
    • Use a Phillips screwdriver to remove the two 16.2 mm-long screws securing the freezer evaporator cover.
  7. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 7, изображение 1 из 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 7, изображение 2 из 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 7, изображение 3 из 3
    • Don't try to fully remove the evaporator cover yet, as it's connected to the refrigerator by a few wires in the top right corner.
    • Use your hands to lift the bottom edge of the evaporator cover up to release the lower plastic tabs.
    • Swing the evaporator cover upwards to access the connected wires behind it.
  8. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 8, изображение 1 из 2 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 8, изображение 2 из 2
    • Use your fingers to squeeze and disconnect the fan cable connector from the back wall of the freezer.
  9. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 9, изображение 1 из 1
    • Remove the evaporator cover.
  10. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: шаг 10, изображение 1 из 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: шаг 10, изображение 2 из 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: шаг 10, изображение 3 из 3
    • Guide the fan cable from the evaporator cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  11. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 11, изображение 1 из 1
    • Use a Phillips screwdriver to remove the four 18.3 mm-long screws securing the back panel to the evaporator cover.
  12. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 12, изображение 1 из 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 12, изображение 2 из 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 12, изображение 3 из 3
    • Use your fingers to pry and release the clips along the short edge of the evaporator cover.
    • If the perimeter foam insulation prevents you from releasing the clips, cut the foam with scissors.
  13. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 13, изображение 1 из 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 13, изображение 2 из 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 13, изображение 3 из 3
    • Lift and separate the back panel from the evaporator cover.
  14. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 14, изображение 1 из 1
    • Use a Phillips screwdriver to remove the three 14.2 mm-long screws securing the fan to the evaporator cover.
  15. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 15, изображение 1 из 1
    • Lift and remove the evaporator fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down towards the evaporator cover.
Заключение
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Участник с: 04/14/15
15 885 Репутация
Автор 88 руководств
Команда
Global Fixers Участник Global Fixers
Community
33 членов
Автор 546 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 29
За всё время: 232
