Введение
This guide shows how to replace the evaporator thermistor in your Samsung RF28R7201SG refrigerator.
The Samsung fridge has two evaporators: one for the refrigerator compartment and one for the freezer. This guide is for the refrigerator evaporator thermistor.
This thermistor does not sense the refrigerator compartment temperature. Rather, this thermistor senses the evaporator coil temperature. If this thermistor fails, your refrigerator won't cool the refrigerator compartment properly.
Выберете то, что вам нужно
Open both French doors for the refrigerator compartment.
Remove all the loose shelves and bins from the refrigerator compartment.
Press both plastic tabs firmly with your fingers and lift upward to unclip the bottom shelf.
Remove the bottom shelf.
Use a flathead screwdriver to pry and remove the top screw cover on the evaporator cover.
Use a Phillips screwdriver to remove the four screws securing the evaporator cover:
Two 37 mm-long screws
Two 16.5 mm-long screws
Grasp the right edge of the evaporator cover with your hands and swing it outwards toward you.
Don't try to fully remove the cover in this step, as it's connected by several wires.
Squeeze and disconnect the two wire connectors connecting the evaporator cover to the refrigerator.
Use a flathead screwdriver to pry off and remove the two red connector retaining clips.
Use your fingers to squeeze the thermistor's white connector by the sides.
Pull the connector to disconnect it.
Use snips or scissors to cut any cable ties securing the yellow thermistor cable.
Use your fingers to twist and unclip the thermistor from the evaporator coil.
Remove the evaporator thermistor.
Repair didn’t go as planned? Ask our Answers community for help.
