Введение
This guide shows how to remove and replace the Wi-Fi card in your Samsung RF28R7201SG refrigerator.
The Wi-Fi card resides in the top hinge cover. If your fridge has trouble connecting to the local Wi-Fi network, first make sure that the hinge cover doesn't have any metallic items placed over it (which can severely block wireless signals). If the fridge can't pick up any Wi-Fi signals, you may need to replace the Wi-Fi card.
Выберете то, что вам нужно
Use a Phillips screwdriver to remove the three 18.5 mm-long screws securing the hinge cover on the top of the refrigerator.
Lift the edges of the hinge cover to loosen it from the refrigerator.
Flip the hinge cover over to access the cables underneath.
Use your fingers to squeeze and disconnect the blue wire connector.
Use your fingers to squeeze and disconnect the white wire connector.
The Wi-Fi card is attached to the hinge cover.
Use your fingers to squeeze and slide the Wi-Fi cable connector out of its socket.
Use a Phillips screwdriver to remove the two 9.7 mm-long screws securing the Wi-Fi card to the hinge cover.
Repair didn’t go as planned? Ask our Answers community for help.
