Samsung Refrigerator Control Panel Replacement
Выберете то, что вам нужно
  1. Samsung Refrigerator Control Panel Replacement, Unplug your refrigerator: шаг 1, изображение 1 из 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: шаг 2, изображение 1 из 2 Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: шаг 2, изображение 2 из 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Control Panel Replacement, Loosen the control panel: шаг 3, изображение 1 из 3 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: шаг 3, изображение 2 из 3 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: шаг 3, изображение 3 из 3
    • The control panel has plastic clips around its perimeter that secure it to the refrigerator wall.
    • Insert a spudger into the seam along the right edge of the control panel.
    • You can also use a flathead screwdriver, but be careful not to let the screwdriver slip, or you'll scratch your refrigerator surface.
    • Press the spudger in firmly and pry to loosen the panel.
    • Use your spudger to slide and pry around the control panel to loosen it from the refrigerator wall.
  4. Samsung Refrigerator Control Panel Replacement: шаг 4, изображение 1 из 1
    • Flip the control panel over to reveal the cable connector.
  5. Samsung Refrigerator Control Panel Replacement: шаг 5, изображение 1 из 2 Samsung Refrigerator Control Panel Replacement: шаг 5, изображение 2 из 2
    • Use your fingers to slide the cable connector out of its socket.
  6. Samsung Refrigerator Control Panel Replacement, Remove the control panel: шаг 6, изображение 1 из 1
    • Remove the control panel.
Заключение
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Участник с: 04/14/15
15 945 Репутация
Автор 89 руководств
Команда
Team Vulcan Участник Team Vulcan
Staff
6 членов
Автор 212 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 33
За последние 30 дней: 101
За всё время: 3,460
