Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement
Выберете то, что вам нужно
  1. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Unplug your refrigerator: шаг 1, изображение 1 из 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Open the freezer drawer: шаг 2, изображение 1 из 1
    • Slide the freezer drawer fully open.
  3. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer bins: шаг 3, изображение 1 из 1
    • Lift and remove all the freezer bins from the drawer.
    • You should be left with a freezer door attached by two rails.
  4. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: шаг 4, изображение 1 из 3 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: шаг 4, изображение 2 из 3 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: шаг 4, изображение 3 из 3
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 5, изображение 1 из 2 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 5, изображение 2 из 2
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  6. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer compartment evaporator cover: шаг 6, изображение 1 из 1
    • Remove the screws securing the freezer evaporator cover.
  7. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 7, изображение 1 из 3 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 7, изображение 2 из 3 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 7, изображение 3 из 3
    • Don't try to fully remove the evaporator cover yet, as it's connected to the refrigerator by a few wires in the top right corner.
    • Use your hands to lift the bottom edge of the evaporator cover up to release the lower plastic tabs.
    • Swing the evaporator cover upwards to access the connected wires behind it.
  8. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 8, изображение 1 из 2 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 8, изображение 2 из 2
    • Use your fingers to squeeze and disconnect the fan cable connector from the back wall of the freezer.
  9. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 9, изображение 1 из 1
    • Remove the evaporator cover.
  10. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: шаг 10, изображение 1 из 3 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: шаг 10, изображение 2 из 3 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: шаг 10, изображение 3 из 3
    • Guide the fan cable from the evaporator cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  11. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 11, изображение 1 из 1
    • Remove the screws securing the back panel to the evaporator cover.
  12. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 12, изображение 1 из 3 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 12, изображение 2 из 3 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 12, изображение 3 из 3
    • Use your fingers to pry and release the clips along the short edge of the evaporator cover.
    • If the perimeter foam insulation prevents you from releasing the clips, cut the foam with scissors.
  13. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 13, изображение 1 из 3 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 13, изображение 2 из 3 Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 13, изображение 3 из 3
    • Lift and separate the back panel from the evaporator cover.
  14. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 14, изображение 1 из 1
    • Remove the screws securing the fan to the evaporator cover.
  15. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: шаг 15, изображение 1 из 1
    • Lift and remove the evaporator fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down towards the evaporator cover.
Заключение
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Участник с: 04/14/15
15 927 Репутация
Автор 88 руководств
Команда
Global Fixers Участник Global Fixers
Community
33 членов
Автор 574 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 12
За последние 7 дней: 50
За последние 30 дней: 219
За всё время: 1,918
