Введение
This guide shows how to remove and replace the Wi-Fi card in your Samsung refrigerator.
The Wi-Fi card resides in the top hinge cover. If your fridge has trouble connecting to the local Wi-Fi network, first make sure that the hinge cover doesn't have any metallic items placed over it (which can severely block wireless signals). If the fridge can't pick up any Wi-Fi signals, you may need to replace the Wi-Fi card.
This guide will work for most Samsung Refrigerators . This guide is based on a model RF28R7201SG Refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Выберете то, что вам нужно
Remove the screws securing the hinge cover (aka top table) on the top of the refrigerator.
Lift the edges of the hinge cover to loosen it from the refrigerator.
Flip the hinge cover over to access the cables underneath.
Use your fingers to release the wire connectors under the hinge cover.
Disconnect the wiring so you can remove the hinge cover.
The Wi-Fi card is attached to the hinge cover.
Use your fingers to squeeze and slide the Wi-Fi cable connector out of its socket.
Repair didn’t go as planned? Ask our Answers Community for help.
Еще один человек закончил это руководство.
3 Комментариев
Hi nico, can you share pictures for the cables of this wifi module? pin colors and order please in both sides ? Thank you.
Thank-you for this Detailed replacement step. I do have one question: I am currently having an issue with my Refrigerator dropping its WIFI connection when the refrigerator door is opened or closed (same model). When it drops it goes back into AP mode and constantly chimes. If I wanted to just 'disable' WIFI all together on this refrigerator, could I just unplug the WIFI cable from the card and leave it unplugged? Would the refrigerator still function normal without this card and stop chiming to setup WIFI?
I have this model RS27T5561SR the WiFi is not working at all. Where can I purchase the WiFi chip from? Thanks
