Введение
For the updated iFixit guide, click here. This guide is archived for historical purposes.
Inside a Samsung S20 Plus and how to repair screen
Apply lots of heat to back glass
Выберете то, что вам нужно
Видеообзор
I pry straight down at bottom of back glass to get tool under glass work my way around slowly lifting with my fingers!
Remove 9 PH000 Screws from top of wireless charging pad
1 PH000 Screw holding down the motherboard
Remove 5 PH000 Screws over the charge port removing loudspeaker
Fold wireless charging cover upwards to unplug battery 1st
Disconnect Battery
Disconnect Wireless Charging Pad
Disconnect these connections
Keep Charge Port Connections and Remove
Unscrew 3 PH000 Screws from charge port
Lift from top
Wiggle sideways upwards to pull out charge port
Remove this part will have to go in screen assembly 2 PH000 Screws
Remove this part 2 PH000 Screws
Sorry for lack of pictures removing back glass
