Введение
Use this guide to replace the Bluetooth antenna in a Skullcandy Crusher Wireless headphones. A replacement Bluetooth antenna can be bought online.
Follow this replacement guide if you've identified the Bluetooth antenna as a source of a problem (or maybe you just want to see the internal components of your Skullcandy Crusher Wireless). For more information, refer to the Troubleshooting page.
Also, for more information about soldering and desoldering, please use this guide.
Выберете то, что вам нужно
Take your headphones and hold them upside down for better control with your hands.
Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
Gently pry the speaker assembly away from the frame of the headphones.
The Bluetooth antenna module chip is located on the right top corner of the motherboard.
If necessary, the chip module can be desoldered and replaced with a new one. Or, the motherboard can be replaced.
Еще один человек закончил это руководство.
