Smart Soldering Iron Complete Disassembly
Выберете то, что вам нужно
  1. Smart Soldering Iron Complete Disassembly, How to read the Touch-Safe Indicator LED: шаг 1, изображение 1 из 3 Smart Soldering Iron Complete Disassembly, How to read the Touch-Safe Indicator LED: шаг 1, изображение 2 из 3 Smart Soldering Iron Complete Disassembly, How to read the Touch-Safe Indicator LED: шаг 1, изображение 3 из 3
    • The color of the Touch-Safe Indicator LED provides information about the status of the soldering iron tip. Note: the soldering iron grip is always safe to touch.
    • The LED only functions when the soldering iron is connected to a power source—so use caution when handling an unplugged iron if you don't know how hot it is.
    • Blue LED: The iron has cooled below 40 °C (100 °F), and the tip is safe to touch.
    • Purple LED: When pulsing, the iron is actively heating up or cooling down. When static, the iron is in Idle Mode. The iron tip is not safe to touch.
    • Orange LED: The iron has reached the set temperature and is ready to solder. The iron tip is not safe to touch.
  2. Smart Soldering Iron Complete Disassembly, Turn off the iron: шаг 2, изображение 1 из 3 Smart Soldering Iron Complete Disassembly, Turn off the iron: шаг 2, изображение 2 из 3 Smart Soldering Iron Complete Disassembly, Turn off the iron: шаг 2, изображение 3 из 3
    • The sliding power switch has a built-in color indicator for each position:
    • Orange: ON
    • Blue: OFF
    • Slide the power switch to the blue OFF position.
    • The LED will turn purple and pulse to show the iron is powering down.
    • Leave the soldering iron connected until the indicator ring turns blue, indicating it's now safe to touch the soldering iron tip.
    • Remember: The LED only functions when the soldering iron is connected to a power source—so use caution when handling an unplugged iron if you don't know how hot it is.
  3. Smart Soldering Iron Complete Disassembly, Unplug the iron: шаг 3, изображение 1 из 2 Smart Soldering Iron Complete Disassembly, Unplug the iron: шаг 3, изображение 2 из 2
    • Disconnect the iron's USB-C cable from your power source.
  4. Smart Soldering Iron Complete Disassembly, Unlock the locking collar: шаг 4, изображение 1 из 3 Smart Soldering Iron Complete Disassembly, Unlock the locking collar: шаг 4, изображение 2 из 3 Smart Soldering Iron Complete Disassembly, Unlock the locking collar: шаг 4, изображение 3 из 3
    • Twist the blue cable collar counter-clockwise and pull up to release it from the iron.
  5. Smart Soldering Iron Complete Disassembly, Disconnect the cable from the iron: шаг 5, изображение 1 из 2 Smart Soldering Iron Complete Disassembly, Disconnect the cable from the iron: шаг 5, изображение 2 из 2
    • Disconnect the USB-C cable from the Smart Soldering Iron.
  6. Smart Soldering Iron Complete Disassembly, Remove the soldering iron cap: шаг 6, изображение 1 из 2 Smart Soldering Iron Complete Disassembly, Remove the soldering iron cap: шаг 6, изображение 2 из 2
    • Hold the iron from both ends and pull to remove the cap.
  7. Smart Soldering Iron Complete Disassembly, Remove the cap screw: шаг 7, изображение 1 из 2 Smart Soldering Iron Complete Disassembly, Remove the cap screw: шаг 7, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Phillips #1 Screwdriver
    $5.49
    • Use a Phillips screwdriver to remove the 8.0 mm‑long screw at the bottom of the opening of the soldering iron cap that secures the cap tip and clip spring to the cap.
    • You will need a long-shaft screwdriver to be able to reach the screw inside of the soldering iron cap.
  8. Smart Soldering Iron Complete Disassembly, Remove the cap lid: шаг 8, изображение 1 из 3 Smart Soldering Iron Complete Disassembly, Remove the cap lid: шаг 8, изображение 2 из 3 Smart Soldering Iron Complete Disassembly, Remove the cap lid: шаг 8, изображение 3 из 3
    • Pull upward on the cap tip to remove it from the cap.
    • During reassembly, fit the iron prongs at the top of the cap into the holes at the bottom interior of the cap tip.
  9. Smart Soldering Iron Complete Disassembly, Remove the cap spring clip: шаг 9, изображение 1 из 3 Smart Soldering Iron Complete Disassembly, Remove the cap spring clip: шаг 9, изображение 2 из 3 Smart Soldering Iron Complete Disassembly, Remove the cap spring clip: шаг 9, изображение 3 из 3
    • Pull up from the bottom of the cap spring clip.
    • Pull the ends of the spring clip straight out through the holes in the cap to remove it.
  10. Smart Soldering Iron Complete Disassembly, Remove the quick-swap soldering tip: шаг 10, изображение 1 из 2 Smart Soldering Iron Complete Disassembly, Remove the quick-swap soldering tip: шаг 10, изображение 2 из 2
    • Make sure the tip has fully cooled before touching it.
    • Firmly grasp the base of the tip and pull it away from the front of the iron handle to remove it.
  11. Smart Soldering Iron Complete Disassembly, Remove the handle screws: шаг 11, изображение 1 из 2 Smart Soldering Iron Complete Disassembly, Remove the handle screws: шаг 11, изображение 2 из 2
    • Use a Phillips screwdriver to remove the three blue 3.4 mm‑long screws securing the blue end cap.
    • Use a Phillips screwdriver to remove the one black 3.4 mm‑long screw at the base of the enclosure.
  12. Smart Soldering Iron Complete Disassembly, Remove the blue end cap: шаг 12, изображение 1 из 2 Smart Soldering Iron Complete Disassembly, Remove the blue end cap: шаг 12, изображение 2 из 2
    • Pull to remove the blue end cap from the rest of the iron handle.
  13. Smart Soldering Iron Complete Disassembly, Remove the power switch: шаг 13, изображение 1 из 2 Smart Soldering Iron Complete Disassembly, Remove the power switch: шаг 13, изображение 2 из 2
    • Remove the blue and orange power switch.
  14. Smart Soldering Iron Complete Disassembly, Remove the main board: шаг 14, изображение 1 из 3 Smart Soldering Iron Complete Disassembly, Remove the main board: шаг 14, изображение 2 из 3 Smart Soldering Iron Complete Disassembly, Remove the main board: шаг 14, изображение 3 из 3
    • Grasp the end of the main board that sticks out from inside of the soldering iron handle.
    • Pull to slide the main board out of the handle.
    • When reassembling your iron, make sure to insert the main board with the shiny iron auxiliary port end first.
  15. Smart Soldering Iron Complete Disassembly, Separate the grip: шаг 15, изображение 1 из 3 Smart Soldering Iron Complete Disassembly, Separate the grip: шаг 15, изображение 2 из 3 Smart Soldering Iron Complete Disassembly, Separate the grip: шаг 15, изображение 3 из 3
    • Twist the iron enclosure below the grip and pull to separate the grip from the enclosure. Just the grip remains.
  16. Smart Soldering Iron Complete Disassembly, Full disassembly: шаг 16, изображение 1 из 1
    • Your Smart Soldering Iron is fully disassembled!
Заключение
To reassemble your Smart Soldering Iron, follow these instructions in reverse order.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Еще один человек закончил это руководство.
Прикрепленные документы
Kara Piepenbrink
Участник с: 05/31/24
5 474 Репутация
Автор 21 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 629 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 22
За последние 30 дней: 132
За всё время: 1,734
