Введение
If your Sonos Roam is having battery issues such as not being able to hold a charge or not charging at all, then use this guide to replace the battery.
The battery is responsible for providing the energy that the speaker uses to function. It can be charged, store the energy, and provide energy when needed.
Before using this guide, make sure your current charger is compatible and you have the right USB cable. Also try rebooting the device.
There are steps that recommend (not require) the use of the iOpener. This will help with carefully removing the adhesive used to keep this device together. Refer to this link on how to properly use the iOpener.
Выберете то, что вам нужно
Use the metal spudger to pry the end cap with the buttons.
Pry from all sides to loosen the adhesive.
Flip the device to the other end cap.
Use the metal spudger to loosen the adhesive.
Flip the device so that the Sonos logo is on the top.
Use the Torx T6 screwdriver to remove the two 6 mm screws.
Flip the device so the Sonos logo is on the top.
Use the iFixit opening picks to wedge between the split of the grille and the back of the speaker to pry the grille apart.
Use the TR10 Torx screwdriver to remove the four 7 mm screws.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use the tweezers to flip the latch holding the large ribbon in place.
Grab the large ribbon with the tweezers and pull upwards to remove it.
Use the tweezers to flip the latch holding the small ribbon in place.
Grab the small ribbon with the tweezers and pull upwards to remove it.
Grab the metal piece sticking out of the outer circuit board.
Pull upwards to remove the outer circuit board.
Use a soldering iron to desolder the outer circuit board from the speaker casing.
5 участников успешно повторили данное руководство.
