Введение
Use this guide to remove or replace a broken or defective rear camera in a Sony Xperia Z5.
If you do not replace the adhesive seals when reassembling, your device will function normally, but will most likely lose its water-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Выберете то, что вам нужно
Before you begin, switch off your phone.
Apply a heated iOpener to the edges on the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
Pull up the suction handle to generate a gap.
Insert an opening pick into the gap to further separate the rear glass from the phone assembly.
Use a spudger to pry up and disconnect the battery flex cable.
Еще один человек закончил это руководство.
