SteelSeries Nimbus+ Controller Face Buttons Replacement
Выберете то, что вам нужно
  1. SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the phone mount: шаг 1, изображение 1 из 2 SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the phone mount: шаг 1, изображение 2 из 2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the sticker: шаг 2, изображение 1 из 1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. SteelSeries Nimbus+ Controller Face Buttons Replacement, Unscrew the back cover: шаг 3, изображение 1 из 1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. SteelSeries Nimbus+ Controller Face Buttons Replacement, Insert an opening pick: шаг 4, изображение 1 из 2 SteelSeries Nimbus+ Controller Face Buttons Replacement, Insert an opening pick: шаг 4, изображение 2 из 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. SteelSeries Nimbus+ Controller Face Buttons Replacement, Release the plastic clips: шаг 5, изображение 1 из 2 SteelSeries Nimbus+ Controller Face Buttons Replacement, Release the plastic clips: шаг 5, изображение 2 из 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. SteelSeries Nimbus+ Controller Face Buttons Replacement, Insert an opening pick: шаг 6, изображение 1 из 2 SteelSeries Nimbus+ Controller Face Buttons Replacement, Insert an opening pick: шаг 6, изображение 2 из 2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. SteelSeries Nimbus+ Controller Face Buttons Replacement, Release the plastic clips: шаг 7, изображение 1 из 2 SteelSeries Nimbus+ Controller Face Buttons Replacement, Release the plastic clips: шаг 7, изображение 2 из 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. SteelSeries Nimbus+ Controller Face Buttons Replacement, Unfold the back cover assembly: шаг 8, изображение 1 из 3 SteelSeries Nimbus+ Controller Face Buttons Replacement, Unfold the back cover assembly: шаг 8, изображение 2 из 3 SteelSeries Nimbus+ Controller Face Buttons Replacement, Unfold the back cover assembly: шаг 8, изображение 3 из 3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. SteelSeries Nimbus+ Controller Face Buttons Replacement, Disconnect the battery cable: шаг 9, изображение 1 из 3 SteelSeries Nimbus+ Controller Face Buttons Replacement, Disconnect the battery cable: шаг 9, изображение 2 из 3 SteelSeries Nimbus+ Controller Face Buttons Replacement, Disconnect the battery cable: шаг 9, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the back cover assembly: шаг 10, изображение 1 из 1
    • Remove the back cover assembly.
  11. SteelSeries Nimbus+ Controller Face Buttons Replacement, Unscrew the board: шаг 11, изображение 1 из 1
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
  12. SteelSeries Nimbus+ Controller Face Buttons Replacement, Disconnect the thumbstick board: шаг 12, изображение 1 из 3 SteelSeries Nimbus+ Controller Face Buttons Replacement, Disconnect the thumbstick board: шаг 12, изображение 2 из 3 SteelSeries Nimbus+ Controller Face Buttons Replacement, Disconnect the thumbstick board: шаг 12, изображение 3 из 3
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
  13. SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the board: шаг 13, изображение 1 из 1
    • Remove the board with the thumbsticks from the mainboard.
  14. SteelSeries Nimbus+ Controller Face Buttons Replacement, Unscrew the mainboard: шаг 14, изображение 1 из 1
    • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
  15. SteelSeries Nimbus+ Controller Face Buttons Replacement, Lift up the mainboard: шаг 15, изображение 1 из 3 SteelSeries Nimbus+ Controller Face Buttons Replacement, Lift up the mainboard: шаг 15, изображение 2 из 3 SteelSeries Nimbus+ Controller Face Buttons Replacement, Lift up the mainboard: шаг 15, изображение 3 из 3
    • Use your fingers to lift up the mainboard from the front case.
    • Remove the mainboard.
  16. SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the face buttons: шаг 16, изображение 1 из 3 SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the face buttons: шаг 16, изображение 2 из 3 SteelSeries Nimbus+ Controller Face Buttons Replacement, Remove the face buttons: шаг 16, изображение 3 из 3
    • Use a pair of tweezers to remove the face buttons from the housing.
    • The alignment pegs on each button are designed to prevent incorrect installation. Make sure your new buttons fit properly in the controller case.
Заключение
Adriana Zwink
Участник с: 12/18/19
66 732 Репутация
Автор 167 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 25 685 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 10
За последние 30 дней: 41
За всё время: 614
