SteelSeries Stratus Duo Charging Port Replacement
Выберете то, что вам нужно
  1. SteelSeries Stratus Duo Charging Port Replacement, Remove the sticker: шаг 1, изображение 1 из 2 SteelSeries Stratus Duo Charging Port Replacement, Remove the sticker: шаг 1, изображение 2 из 2
    • Use your fingers to remove the sticker located on the back cover of the Stratus Duo.
    • If you have trouble removing the sticker, heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath. You can also use a hair dryer to soften the adhesive.
  2. SteelSeries Stratus Duo Charging Port Replacement, Unscrew the back cover: шаг 2, изображение 1 из 1
    • Use a Y0 Tri-point screwdriver to remove the five 9.3 mm-long screws securing the back cover.
  3. SteelSeries Stratus Duo Charging Port Replacement, Reposition the back cover assembly: шаг 3, изображение 1 из 3 SteelSeries Stratus Duo Charging Port Replacement, Reposition the back cover assembly: шаг 3, изображение 2 из 3 SteelSeries Stratus Duo Charging Port Replacement, Reposition the back cover assembly: шаг 3, изображение 3 из 3
    • Don't try to remove the back cover assembly all the way yet, as it's still connected to the mainboard.
    • Carefully lift the back cover assembly away from the frame and move it downward to uncover the battery cable and the interconnect cable at the top of the motherboard.
  4. SteelSeries Stratus Duo Charging Port Replacement, Disconnect the interconnect cable: шаг 4, изображение 1 из 3 SteelSeries Stratus Duo Charging Port Replacement, Disconnect the interconnect cable: шаг 4, изображение 2 из 3 SteelSeries Stratus Duo Charging Port Replacement, Disconnect the interconnect cable: шаг 4, изображение 3 из 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
  5. SteelSeries Stratus Duo Charging Port Replacement: шаг 5, изображение 1 из 2 SteelSeries Stratus Duo Charging Port Replacement: шаг 5, изображение 2 из 2
    • Use a pair of blunt nosed tweezers or your fingers to pull the cable out of the socket.
  6. SteelSeries Stratus Duo Charging Port Replacement, Disconnect the battery cable: шаг 6, изображение 1 из 3 SteelSeries Stratus Duo Charging Port Replacement, Disconnect the battery cable: шаг 6, изображение 2 из 3 SteelSeries Stratus Duo Charging Port Replacement, Disconnect the battery cable: шаг 6, изображение 3 из 3
    • Use a pair of blunt nose tweezers to grab and lift the connector away from the motherboard.
  7. SteelSeries Stratus Duo Charging Port Replacement, Remove the back cover assembly: шаг 7, изображение 1 из 1
    • Remove the back cover assembly.
  8. SteelSeries Stratus Duo Charging Port Replacement, Pry up the battery: шаг 8, изображение 1 из 2 SteelSeries Stratus Duo Charging Port Replacement, Pry up the battery: шаг 8, изображение 2 из 2
    • The battery is held in place by mild adhesive.
    • Insert the long edge of an opening pick into the gap between the battery and the back cover assembly.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use the opening pick to carefully pry up the battery and separate the adhesive.
  9. SteelSeries Stratus Duo Charging Port Replacement, Remove the battery: шаг 9, изображение 1 из 3 SteelSeries Stratus Duo Charging Port Replacement, Remove the battery: шаг 9, изображение 2 из 3 SteelSeries Stratus Duo Charging Port Replacement, Remove the battery: шаг 9, изображение 3 из 3
    • Grab the battery with your fingers and lift it out of its recess to remove it.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • During reassembly make sure to align the battery and the back cover correctly.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card.
  10. SteelSeries Stratus Duo Charging Port Replacement, Unscrew the plastic bracket: шаг 10, изображение 1 из 1
    • Use a Phillips screwdriver to remove the two 7.2 mm-long screws securing the plastic bracket that holds the charging port and the Bluetooth/power buttons in place.
  11. SteelSeries Stratus Duo Charging Port Replacement, Remove the plastic bracket: шаг 11, изображение 1 из 3 SteelSeries Stratus Duo Charging Port Replacement, Remove the plastic bracket: шаг 11, изображение 2 из 3 SteelSeries Stratus Duo Charging Port Replacement, Remove the plastic bracket: шаг 11, изображение 3 из 3
    • Use your fingers to push the plastic bracket downwards into the recess of the battery to loosen it.
    • Remove the plastic bracket.
  12. SteelSeries Stratus Duo Charging Port Replacement, Remove the charging port: шаг 12, изображение 1 из 1
    • Remove the charging port.
Заключение
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
Участник с: 12/18/19
45 268 Репутация
Автор 167 руководств
Команда
iFixit Участник iFixit
Community
142 членов
Автор 16 235 руководств
Один комментарий
Where can i get the replacement board? Stratus is not responding to my messages.
ryan olson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 342
