Valve Index Headset Head Strap Replacement
Выберете то, что вам нужно
  1. Valve Index Headset Head Strap Replacement, Adjust the eye tube relief: шаг 1, изображение 1 из 1
    • Twist the eye tube relief knob clockwise to fully extend it.
  2. Valve Index Headset Head Strap Replacement, Remove the eye relief knob: шаг 2, изображение 1 из 3 Valve Index Headset Head Strap Replacement, Remove the eye relief knob: шаг 2, изображение 2 из 3 Valve Index Headset Head Strap Replacement, Remove the eye relief knob: шаг 2, изображение 3 из 3
    • Insert an opening pick between the eye relief knob and the head strap.
    • Gently pry with the opening pick while pulling the eye relief knob off until it is removed.
  3. Valve Index Headset Head Strap Replacement, Reassembly tip: шаг 3, изображение 1 из 1
    • During reassembly, ensure the eye relief knob is aligned with the shaft before pressing it on.
  4. Valve Index Headset Head Strap Replacement, Remove the head strap clip: шаг 4, изображение 1 из 3 Valve Index Headset Head Strap Replacement, Remove the head strap clip: шаг 4, изображение 2 из 3 Valve Index Headset Head Strap Replacement, Remove the head strap clip: шаг 4, изображение 3 из 3
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
  5. Valve Index Headset Head Strap Replacement, Remove the face gasket: шаг 5, изображение 1 из 2 Valve Index Headset Head Strap Replacement, Remove the face gasket: шаг 5, изображение 2 из 2
    • Use your hand to gently pull the face gasket straight off of the headset.
    • The face gasket is held in place by four magnets that secure to screws in the face bezel.
    • Before installing a face gasket, ensure the four screws securing the face gasket bezel are installed. Otherwise, the face gasket will not stay in place.
  6. Valve Index Headset Head Strap Replacement, Separate the cable from the head strap guide: шаг 6, изображение 1 из 2 Valve Index Headset Head Strap Replacement, Separate the cable from the head strap guide: шаг 6, изображение 2 из 2
    • Use your fingers to pull the tether cable straight up off of the head strap cable guide.
  7. Valve Index Headset Head Strap Replacement, Disconnect the tether cable: шаг 7, изображение 1 из 2 Valve Index Headset Head Strap Replacement, Disconnect the tether cable: шаг 7, изображение 2 из 2
    • Pull the tether cable straight back out of the headset.
  8. Valve Index Headset Head Strap Replacement, Head strap removal information: шаг 8, изображение 1 из 2 Valve Index Headset Head Strap Replacement, Head strap removal information: шаг 8, изображение 2 из 2
    • The head strap can be removed without removing the face gasket bezel if you have the correct length driver. If you are using your iFixit T6 driver, skip this step and proceed with removing the face gasket bezel.
    • Your T6 driver must have a shaft longer than 18 mm (0.7 in) and an overall length less than 140 mm (5.5 in).
    • Insert your T6 Torx screwdriver into the hole on the face gasket bezel to remove the captive screw securing the left side of the head strap.
    • Skip to step 12.
  9. Valve Index Headset Head Strap Replacement, Remove the face gasket bezel: шаг 9, изображение 1 из 1
    • Use a T5 Torx screwdriver to remove the four 6.0 mm screws securing the face gasket bezel to the headset.
  10. Valve Index Headset Head Strap Replacement: шаг 10, изображение 1 из 2 Valve Index Headset Head Strap Replacement: шаг 10, изображение 2 из 2
    • Do not try and pry the face gasket bezel off, or you will damage the headset.
    • Grab the left edge of the face gasket bezel with your hand and slide it off of the headset.
    • During reassembly, visually verify the clips on the face gasket bezel are aligned with the headset before sliding it into place.
  11. Valve Index Headset Head Strap Replacement: шаг 11, изображение 1 из 3 Valve Index Headset Head Strap Replacement: шаг 11, изображение 2 из 3 Valve Index Headset Head Strap Replacement: шаг 11, изображение 3 из 3
    • Repeat the previous step for the right side of the face gasket bezel.
    • Remove the face gasket bezel.
  12. Valve Index Headset Head Strap Replacement, Remove the head strap: шаг 12, изображение 1 из 1
    • Use a T6 Torx screwdriver to remove the two 6.6 mm screws underneath the eye relief knob.
  13. Valve Index Headset Head Strap Replacement: шаг 13, изображение 1 из 2 Valve Index Headset Head Strap Replacement: шаг 13, изображение 2 из 2
    • Pull the right end of the head strap straight off of the headset.
    • During reassembly, ensure the head strap is correctly positioned on the alignment post.
  14. Valve Index Headset Head Strap Replacement: шаг 14, изображение 1 из 2 Valve Index Headset Head Strap Replacement: шаг 14, изображение 2 из 2
    • Use a T6 Torx screwdriver to loosen the screw securing the left side of the head strap to the headset.
    • Don't let this screw fall inside the headset. It is not a captive screw and is difficult to retrieve.
    • If the black plastic cap surrounding the cap limits access, use an opening pick to remove the cap.
  15. Valve Index Headset Head Strap Replacement: шаг 15, изображение 1 из 2 Valve Index Headset Head Strap Replacement: шаг 15, изображение 2 из 2
    • Pull the left end of the head strap straight off the headset.
    • During reassembly, be careful not to let the screw fall into the headset. Use your driver to hold it in place from behind if necessary.
  16. Valve Index Headset Head Strap Replacement: шаг 16, изображение 1 из 2 Valve Index Headset Head Strap Replacement: шаг 16, изображение 2 из 2
    • Slide the head strap band out from the headset.
    • The head strap is now fully removed.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
24 участников успешно повторили данное руководство.
Sam Omiotek
Участник с: 02/25/19
73 624 Репутация
Автор 288 руководств
3 Комментариев
I'm having troubles with my left speaker, I just got done replacing it, is this the next step I wanna try in troubleshooting it? The last thing I want to do is buy a whole new headset? It cuts out when the strap moves. I've already replaced the cable as well.
Who? - Ответить
Try to tighten left part of the strap (step 14)
Анатолий Прилуцкий -
When will they be in stock again
lightning gaming - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 35
За последние 7 дней: 238
За последние 30 дней: 1,235
За всё время: 29,506
