Введение
Follow this guide to replace the motherboard in a Valve Index VR headset.
Power off and unplug your Index before you begin your repair.
Выберете то, что вам нужно
Use your hand to pull the front cover straight off of the front of the headset.
Use a T5 Torx screwdriver to remove the four 5.4 mm screws securing the motherboard cover to the headset.
Use a T5 Torx screwdriver to remove the following eight screws from the front fascia:
Four 6.3 mm screws with fine threads
Four 6.0 mm screws with coarse threads
Use a spudger to unlock the ZIF connector at the top-left corner of the motherboard.
Disconnect the FPC ribbon cable from the motherboard.
Use a spudger to unlock the ZIF connector at the top-right corner of the motherboard.
Disconnect the FPC ribbon cable.
Use the flat end of a spudger to disconnect the press connector from the bottom-left corner of the motherboard.
Use the flat end of a spudger to disconnect the press connector from the bottom-right corner of the motherboard.
Insert an opening pick in between the front fascia and the headset.
Slide the opening pick over to separate the front fascia from the headset.
Continue sliding the opening pick along the perimeter of the front fascia until all edges are free.
Note the seven cables that must be disconnected in the following steps before the motherboard can be removed.
Use the flat end of a spudger to unlock the wide ZIF connector on the left side of the motherboard.
Use the flat end of a spudger to disconnect the press connector near the bottom-left edge of the motherboard.
Use your finger or an opening tool to unlock the display cable connector at the top of the motherboard.
Carefully disconnect the display cable connector.
Use the pointed end of a spudger to gently disconnect the bundled cable connector from the top-right corner of the motherboard.
Use the pointed end of a spudger to unlock the ZIF connector next to the USB port on the motherboard.
Disconnect the FPC cable from the motherboard.
Use the flat end of a spudger to disconnect the press connector below the USB port on the motherboard.
Use a spudger to unlock the wide ZIF connector near the right edge of the motherboard.
Use a T5 Torx screwdriver to remove the five 6.0 mm screws securing the motherboard to the headset.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Еще один человек закончил это руководство.
5 Комментариев
Where can I buy the motherboard? It doesn't look like ifixit has them.
I have this same question.
Same question ,where do i get a replacement main board
