Valve Index Headset Tether and Trident Cable Replacement
Выберете то, что вам нужно
  1. Valve Index Headset Tether and Trident Cable Replacement, Remove the face gasket: шаг 1, изображение 1 из 2 Valve Index Headset Tether and Trident Cable Replacement, Remove the face gasket: шаг 1, изображение 2 из 2
    • Use your hand to gently pull the face gasket straight off of the headset.
    • The face gasket is held in place by four magnets that secure to screws in the face bezel.
    • Before installing a face gasket, ensure the four screws securing the face gasket bezel are installed. Otherwise, the face gasket will not stay in place.
  2. Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: шаг 2, изображение 1 из 3 Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: шаг 2, изображение 2 из 3 Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: шаг 2, изображение 3 из 3
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
  3. Valve Index Headset Tether and Trident Cable Replacement, Separate the cable from the head strap guide: шаг 3, изображение 1 из 2 Valve Index Headset Tether and Trident Cable Replacement, Separate the cable from the head strap guide: шаг 3, изображение 2 из 2
    • Use your fingers to pull the tether cable straight up off of the head strap cable guide.
  4. Valve Index Headset Tether and Trident Cable Replacement, Disconnect the tether cable: шаг 4, изображение 1 из 2 Valve Index Headset Tether and Trident Cable Replacement, Disconnect the tether cable: шаг 4, изображение 2 из 2
    • Pull the tether cable straight back out of the headset.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
11 участников успешно повторили данное руководство.
Sam Omiotek
Участник с: 02/25/19
73 624 Репутация
Автор 288 руководств
Один комментарий
"übersetzer:innen" danke. das erste und letzte mal was gelesen hier.
blub blub - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 29
За последние 7 дней: 202
За последние 30 дней: 824
За всё время: 27,456
