Введение
Use this guide to replace the door sensor or door switch in your Whirlpool WRS315SDHW Refrigerator.
The door switch detects whether or not the door is open or if the control board thinks it's open. If you're having trouble dispensing ice/water, or if your door light won't turn off, then your door switch might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Выберете то, что вам нужно
Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
Pry up to separate the door sensor enough so you can grip it with your fingers.
Pull the door sensor through the chassis enough to access its connector.
Disconnect the spade connector attached to the door sensor.
Remove the door sensor.
Repair didn’t go as planned? Ask our Answers community for help.
Еще один человек закончил это руководство.
