Введение
Use this guide to replace the start relay assembly in your Whirlpool WRS315SDHW Refrigerator.
The start relay is a combination of the start relay, the overload relay, and the start capacitor, which are responsible for protecting your compressor's circuit. If the fans are running and your compressor won’t start, or if you hear a clicking sound from the unit, your start relay assembly might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Выберете то, что вам нужно
Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
Use a flathead screwdriver, or a similar tool, to disconnect the connector attached to the start relay assembly.
Pull the metal clip out its hole in the top of the start relay assembly.
Rest the clip next to the assembly.
Pull the start relay assembly straight off its prongs in the chassis.
Remove the start relay assembly.
Repair didn’t go as planned? Ask our Answers community for help.
