Введение
Use this guide to replace the door light or LED light in your Whirlpool Refrigerator.
The door light illuminates the right side of the refrigerator. If the lighting in your refrigerator is dim or dark, then the door light might be broken.
This guide will work for most Whirlpool refrigerators. This guide is written with a model WRS315SDHW refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Выберете то, что вам нужно
Carefully insert a flathead screwdriver, or a similar tool, between the door light and the chassis.
Pry up to separate the door light enough so you can grip it with your fingers.
Tilt the door light downward to completely release its plastic clips.
Pull the light down to expose its connectors.
Repair didn’t go as planned? Ask our Answers community for help.
2 Комментариев
Hello Gents,
I have a Kitchen aid fridge Model # KRFF300ESS01 and one of the top Led light is flickering they come as a set module # W10897058, and connected by interconnecting wiring, (concealed in the panel) can any one please help me as to how I can change them out.....the other light is good and there is a screw which holds up the plastic panel housing the lights, can I get them out by removing the panel or do I get them out by taking them out one at a time and how do I get the wiring in like that .....cant post any pictures but will appreciate any feed back,
