Xbox Series X Back Panel Replacement
Выберете то, что вам нужно
  1. Xbox Series X Back Panel Replacement, Uncover the back panel screws: шаг 1, изображение 1 из 2 Xbox Series X Back Panel Replacement, Uncover the back panel screws: шаг 1, изображение 2 из 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Back Panel Replacement: шаг 2, изображение 1 из 3 Xbox Series X Back Panel Replacement: шаг 2, изображение 2 из 3 Xbox Series X Back Panel Replacement: шаг 2, изображение 3 из 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X Back Panel Replacement, Remove the back panel screws: шаг 3, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X Back Panel Replacement, Unclip the back panel: шаг 4, изображение 1 из 3 Xbox Series X Back Panel Replacement, Unclip the back panel: шаг 4, изображение 2 из 3 Xbox Series X Back Panel Replacement, Unclip the back panel: шаг 4, изображение 3 из 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X Back Panel Replacement: шаг 5, изображение 1 из 2 Xbox Series X Back Panel Replacement: шаг 5, изображение 2 из 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X Back Panel Replacement, Remove the back panel: шаг 6, изображение 1 из 3 Xbox Series X Back Panel Replacement, Remove the back panel: шаг 6, изображение 2 из 3 Xbox Series X Back Panel Replacement, Remove the back panel: шаг 6, изображение 3 из 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X Back Panel Replacement: шаг 7, изображение 1 из 3 Xbox Series X Back Panel Replacement: шаг 7, изображение 2 из 3 Xbox Series X Back Panel Replacement: шаг 7, изображение 3 из 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
Еще один человек закончил это руководство.
Carsten Frauenheim
Участник с: 03/10/20
157 070 Репутация
Автор 439 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 891 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 20
За последние 7 дней: 121
За последние 30 дней: 559
За всё время: 4,806
