Введение
Instantly increase the speed of your iMac by upgrading the RAM.
Выберете то, что вам нужно
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly near the bottom of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Rotate each of the two RAM retaining arms away from the RAM chip.
Pull the RAM chip straight away from its socket.
31 человек успешно провели ремонт по этому руководству.
2 Комментариев
como se llama la cajita blanca que esta debajo de las memorias y que funcion tiene?
Easy as pie, instructions were right to the point, thank you.
Some models (with light sensor) have only the two outboard screws.
Robert Huber - Ответить
