iPad Mini 6 Speaker Assembly Replacement
Выберете то, что вам нужно
  1. iPad Mini 6 Speaker Assembly Replacement, Apply tape to a cracked screen: шаг 1, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement, Apply tape to a cracked screen: шаг 1, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement, Apply tape to a cracked screen: шаг 1, изображение 3 из 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad Mini 6 Speaker Assembly Replacement, Heat the bottom edge: шаг 2, изображение 1 из 1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. iPad Mini 6 Speaker Assembly Replacement, Screen removal information: шаг 3, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement, Screen removal information: шаг 3, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement, Screen removal information: шаг 3, изображение 3 из 3
    • While you're waiting for the adhesive to loosen, note the following:
    • The areas at the top and bottom of the screen are sensitive to prying.
    • Don't insert a pick more than 3 mm to avoid damaging the screen.
    • There's a long circuit board attached to the screen that sits parallel to the left edge.
    • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
    • The first two images are mirrored for demonstration purposes.
  4. iPad Mini 6 Speaker Assembly Replacement, Insert an opening pick: шаг 4, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement, Insert an opening pick: шаг 4, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement, Insert an opening pick: шаг 4, изображение 3 из 3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. iPad Mini 6 Speaker Assembly Replacement, Separate the bottom adhesive: шаг 5, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement, Separate the bottom adhesive: шаг 5, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement, Separate the bottom adhesive: шаг 5, изображение 3 из 3
    • Slide the pick along the bottom edge of the device towards the bottom-right corner.
    • Leave the pick in to prevent the adhesive from resealing.
  6. iPad Mini 6 Speaker Assembly Replacement, Heat the right edge: шаг 6, изображение 1 из 1
    • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
  7. iPad Mini 6 Speaker Assembly Replacement, Separate the bottom-right corner adhesive: шаг 7, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement, Separate the bottom-right corner adhesive: шаг 7, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement, Separate the bottom-right corner adhesive: шаг 7, изображение 3 из 3
    • Rotate the opening pick around the bottom-right corner of the device.
  8. iPad Mini 6 Speaker Assembly Replacement, Separate the remaining adhesive: шаг 8, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Separate the remaining adhesive: шаг 8, изображение 2 из 2
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
    • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
  9. iPad Mini 6 Speaker Assembly Replacement, Reposition the screen: шаг 9, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement, Reposition the screen: шаг 9, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement, Reposition the screen: шаг 9, изображение 3 из 3
    • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
  10. iPad Mini 6 Speaker Assembly Replacement, Unfasten the display cable bracket: шаг 10, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Unfasten the display cable bracket: шаг 10, изображение 2 из 2
    • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
  11. iPad Mini 6 Speaker Assembly Replacement, Remove the display cable bracket: шаг 11, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Remove the display cable bracket: шаг 11, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
  12. iPad Mini 6 Speaker Assembly Replacement, Disconnect the display: шаг 12, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement, Disconnect the display: шаг 12, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement, Disconnect the display: шаг 12, изображение 3 из 3
    • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
  13. iPad Mini 6 Speaker Assembly Replacement, Remove the screen: шаг 13, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Remove the screen: шаг 13, изображение 2 из 2
    • Remove the screen from the frame.
  14. iPad Mini 6 Speaker Assembly Replacement, Disconnect the battery: шаг 14, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Disconnect the battery: шаг 14, изображение 2 из 2
    • The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. Внимание: шаг 15 взят из руководства, помеченного как незавершенное.
    iPad Mini 6 Speaker Assembly Replacement, Speaker information: шаг 15, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Speaker information: шаг 15, изображение 2 из 2
  16. Внимание: шаги 16-26 взяты из руководства, помеченного как незавершенное.
    iPad Mini 6 Speaker Assembly Replacement, Unfasten the front camera shield: шаг 16, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Unfasten the front camera shield: шаг 16, изображение 2 из 2
    • The next 11 steps will show how to remove the top speaker.
    • Use a Phillips #000 screwdriver to remove the two 1.2 mm screws securing the front camera shield to the frame.
  17. iPad Mini 6 Speaker Assembly Replacement, Remove the front camera shield: шаг 17, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Remove the front camera shield: шаг 17, изображение 2 из 2
    • Use tweezers, or your fingers, to remove the front camera shield.
  18. iPad Mini 6 Speaker Assembly Replacement, Disconnect the volume button board: шаг 18, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Disconnect the volume button board: шаг 18, изображение 2 из 2
    • Use a spudger to pry up and disconnect the volume button board's press connector secured to the frame.
  19. iPad Mini 6 Speaker Assembly Replacement, Reposition the volume button board's cable: шаг 19, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Reposition the volume button board's cable: шаг 19, изображение 2 из 2
    • Use tweezers, or your fingers, to peel back the volume button board's cable from the top speaker.
  20. iPad Mini 6 Speaker Assembly Replacement, Disconnect the top speaker: шаг 20, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Disconnect the top speaker: шаг 20, изображение 2 из 2
    • Use the point of spudger to pry up and disconnect the top speaker's cable.
    • Be very careful when performing this step; apply equal force to both cords to prevent any damage to the connector.
  21. iPad Mini 6 Speaker Assembly Replacement, Reposition the top speaker's cable: шаг 21, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Reposition the top speaker's cable: шаг 21, изображение 2 из 2
    • The top speaker's cable is lightly adhered to the frame.
    • Gently peel back the cable to separate it from the frame.
  22. iPad Mini 6 Speaker Assembly Replacement, Heat the top speaker: шаг 22, изображение 1 из 1
    • Apply a heated iOpener to the top-left edge of the device for 90 seconds to loosen the top speaker's adhesive.
  23. iPad Mini 6 Speaker Assembly Replacement, Top speaker information: шаг 23, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Top speaker information: шаг 23, изображение 2 из 2
    • Adhesive is located around the perimeter of the speaker.
    • Insert a pick 2 mm to separate this adhesive.
    • Adhesive is also located in the center of the speaker.
    • Insert a pick 7 mm to separate this adhesive.
  24. iPad Mini 6 Speaker Assembly Replacement, Separate the top speaker's adhesive: шаг 24, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement, Separate the top speaker's adhesive: шаг 24, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement, Separate the top speaker's adhesive: шаг 24, изображение 3 из 3
    • Insert an opening pick between the top speaker and the frame.
    • Insert the pick at least 7 mm to separate the center adhesive.
  25. iPad Mini 6 Speaker Assembly Replacement: шаг 25, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement: шаг 25, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement: шаг 25, изображение 3 из 3
    • Slice along the perimeter of the top speaker to separate the adhesive.
  26. iPad Mini 6 Speaker Assembly Replacement, Remove the top speaker: шаг 26, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement, Remove the top speaker: шаг 26, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement, Remove the top speaker: шаг 26, изображение 3 из 3
    • At this point, the perimeter of the speaker should be separated from the frame. If there's still resistance around the edges of the speaker, use an opening pick to cut the adhesive again.
    • Pry up with the opening pick to completely separate the top speaker from the frame.
    • Remove the top speaker.
  27. Внимание: шаги 27-32 взяты из руководства, помеченного как незавершенное.
    iPad Mini 6 Speaker Assembly Replacement, Disconnect the bottom speaker: шаг 27, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Disconnect the bottom speaker: шаг 27, изображение 2 из 2
    • The next six steps will show how to remove the bottom speaker.
    • Use the point of spudger to pry up and disconnect the bottom speaker's cable.
  28. iPad Mini 6 Speaker Assembly Replacement, Heat the bottom speaker: шаг 28, изображение 1 из 1
    • Apply a heated iOpener to the bottom-left edge of the device to loosen the bottom speaker's adhesive.
  29. iPad Mini 6 Speaker Assembly Replacement, Bottom speaker information: шаг 29, изображение 1 из 2 iPad Mini 6 Speaker Assembly Replacement, Bottom speaker information: шаг 29, изображение 2 из 2
    • Insert a pick 9 mm to separate this adhesive.
  30. iPad Mini 6 Speaker Assembly Replacement, Separate the bottom speaker's adhesive: шаг 30, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement, Separate the bottom speaker's adhesive: шаг 30, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement, Separate the bottom speaker's adhesive: шаг 30, изображение 3 из 3
    • Insert an opening pick between the bottom speaker and the frame.
    • Insert the pick at least 9 mm to separate the center adhesive.
  31. iPad Mini 6 Speaker Assembly Replacement: шаг 31, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement: шаг 31, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement: шаг 31, изображение 3 из 3
    • Slice along the perimeter of the bottom speaker to separate the adhesive.
  32. iPad Mini 6 Speaker Assembly Replacement, Remove the bottom speaker: шаг 32, изображение 1 из 3 iPad Mini 6 Speaker Assembly Replacement, Remove the bottom speaker: шаг 32, изображение 2 из 3 iPad Mini 6 Speaker Assembly Replacement, Remove the bottom speaker: шаг 32, изображение 3 из 3
    • Pry up with the opening pick to completely separate the bottom speaker from the frame.
    • Remove the bottom speaker.
Заключение
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
Еще один человек закончил это руководство.
Alex Diaz-Kokaisl
Участник с: 01/16/22
213 142 Репутация
Автор 1 040 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 629 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 9
За последние 30 дней: 50
За всё время: 2,460
