iPhone 5 Rear Case Replacement
Выберете то, что вам нужно
Видеообзор
  1. iPhone 5 Rear Case Replacement, Taping the display glass: шаг 1, изображение 1 из 3 iPhone 5 Rear Case Replacement, Taping the display glass: шаг 1, изображение 2 из 3 iPhone 5 Rear Case Replacement, Taping the display glass: шаг 1, изображение 3 из 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 5 Rear Case Replacement, Remove the Pentalobe screws: шаг 2, изображение 1 из 1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
    Спросите у FixBot
  3. iPhone 5 Rear Case Replacement, How to prevent display separation: шаг 3, изображение 1 из 3 iPhone 5 Rear Case Replacement, How to prevent display separation: шаг 3, изображение 2 из 3 iPhone 5 Rear Case Replacement, How to prevent display separation: шаг 3, изображение 3 из 3
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
    Спросите у FixBot
  4. iPhone 5 Rear Case Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 5 Rear Case Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 5 Rear Case Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  5. iPhone 5 Rear Case Replacement: шаг 5, изображение 1 из 3 iPhone 5 Rear Case Replacement: шаг 5, изображение 2 из 3 iPhone 5 Rear Case Replacement: шаг 5, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    Спросите у FixBot
  6. iPhone 5 Rear Case Replacement, Manual Opening Procedure: шаг 6, изображение 1 из 1
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    • If you're opening an iPhone with cracked glass, neatly lay a couple strips of packing tape across the front and squeeze out as many bubbles as you can. This will give the suction cup a surface to grab, and minimize the spread of broken glass.
    Спросите у FixBot
  7. iPhone 5 Rear Case Replacement, Start lifting the front panel assembly: шаг 7, изображение 1 из 1
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The screen is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
    Спросите у FixBot
  8. iPhone 5 Rear Case Replacement, Detaching the front panel side clips: шаг 8, изображение 1 из 1
    • Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
    Спросите у FixBot
  9. iPhone 5 Rear Case Replacement, Opening up the phone: шаг 9, изображение 1 из 3 iPhone 5 Rear Case Replacement, Opening up the phone: шаг 9, изображение 2 из 3 iPhone 5 Rear Case Replacement, Opening up the phone: шаг 9, изображение 3 из 3
    • Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
    • Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    Спросите у FixBot
  10. iPhone 5 Rear Case Replacement, Removing the battery connector bracket screws: шаг 10, изображение 1 из 1
    • Remove the following two screws securing the metal battery connector bracket to the logic board:
    • One 1.8 mm Phillips screw
    • One 1.6 mm Phillips screw
    Спросите у FixBot
  11. iPhone 5 Rear Case Replacement, Removing the battery connector bracket: шаг 11, изображение 1 из 1
    • Remove the metal battery connector bracket from the iPhone.
    Спросите у FixBot
  12. iPhone 5 Rear Case Replacement, Disconnecting the battery connector: шаг 12, изображение 1 из 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
    Спросите у FixBot
  13. iPhone 5 Rear Case Replacement, Removing the front panel assembly cable bracket screws: шаг 13, изображение 1 из 1
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.2 mm Phillips screws
    • This screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing, and make sure it gets back into the right place—a magnetized screw may interfere with the compass.
    Спросите у FixBot
  14. iPhone 5 Rear Case Replacement, Removing the front panel assembly cable bracket: шаг 14, изображение 1 из 2 iPhone 5 Rear Case Replacement, Removing the front panel assembly cable bracket: шаг 14, изображение 2 из 2
    • Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
    • During reassembly, clip the left-hand hooks under the logic board and lower the bracket towards the outside of the phone.
    Спросите у FixBot
  15. iPhone 5 Rear Case Replacement, Disconnecting the front panel assembly cables: шаг 15, изображение 1 из 3 iPhone 5 Rear Case Replacement, Disconnecting the front panel assembly cables: шаг 15, изображение 2 из 3 iPhone 5 Rear Case Replacement, Disconnecting the front panel assembly cables: шаг 15, изображение 3 из 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
    • Front-facing camera and sensor cable
    • LCD cable
    • Digitizer cable
    • When reassembling your phone, the LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
    Спросите у FixBot
  16. iPhone 5 Rear Case Replacement, Separating front panel assembly and rear case: шаг 16, изображение 1 из 1
    • Remove the front panel assembly from the rear case.
    Спросите у FixBot
  17. iPhone 5 Rear Case Replacement, Lifting the battery: шаг 17, изображение 1 из 1
    • Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
    • If you are having trouble peeling the battery up or if the tab breaks, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery.
    • Wait about one minute for the alcohol solution to weaken the adhesive. Use an opening tool to gently lift the battery by its edge.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • If you still have trouble peeling the battery up, use an iOpener or hair dryer to heat the rear case of the iPhone and soften the adhesive.
    • Overheating the iPhone may ignite the battery.
    Спросите у FixBot
  18. iPhone 5 Rear Case Replacement, Prying up the battery: шаг 18, изображение 1 из 2 iPhone 5 Rear Case Replacement, Prying up the battery: шаг 18, изображение 2 из 2
    • Use the plastic opening tool to gently pry the battery up, only at the outside edge of the phone. Prying anywhere else, especially near the logic board, may result in damage to the logic board.
    • If the battery doesn't pry easily out of the case, apply a few more drops of isopropyl alcohol.
    • Pry gently and evenly to avoid deforming the battery. A bent battery can be a fire hazard.
    • Do not pry at the top portion of the battery, you risk severing the volume control cables.
    Спросите у FixBot
  19. iPhone 5 Rear Case Replacement, Removing the battery: шаг 19, изображение 1 из 1
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • Before you adhere the replacement battery, temporarily reconnect the battery connector to the motherboard socket. This ensures that the battery is properly aligned in its recess.
    • Adhere the battery, disconnect it, and continue reassembling your device.
    • During reassembly, make sure the battery is seated firmly against the rear case. This will prevent any damage to other components when reinstalling the front panel assembly.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
    Спросите у FixBot
  20. iPhone 5 Rear Case Replacement, Logic Board Assembly: шаг 20, изображение 1 из 1
    • Use the tip of a spudger to pry the cellular data antenna cable connector up from its socket on the logic board, just above the speaker enclosure.
    Спросите у FixBot
  21. iPhone 5 Rear Case Replacement: шаг 21, изображение 1 из 1
    • Remove the following two screws securing the top logic board bracket to the rear case:
    • One 1.5 mm Phillips screw
    • One 2.3 mm Phillips screw
    Спросите у FixBot
  22. iPhone 5 Rear Case Replacement: шаг 22, изображение 1 из 2 iPhone 5 Rear Case Replacement: шаг 22, изображение 2 из 2
    • Remove the bracket from the top of the logic board.
    • Be sure not to break off the tiny grounding tab that sticks up off of the bracket next to the rear facing camera.
    • On newer models, the bracket may be attached to the camera housing and will not come completely out.
    Спросите у FixBot
  23. iPhone 5 Rear Case Replacement: шаг 23, изображение 1 из 3 iPhone 5 Rear Case Replacement: шаг 23, изображение 2 из 3 iPhone 5 Rear Case Replacement: шаг 23, изображение 3 из 3
    • Use the flat end of a spudger to disconnect the following three cables from the logic board:
    • Upper interconnect cable
    • Button assembly cable
    • Lower interconnect cable
    Спросите у FixBot
  24. iPhone 5 Rear Case Replacement: шаг 24, изображение 1 из 1
    • Remove the two 1.3 mm Phillips screws from the inner top of the rear case.
    Спросите у FixBot
  25. iPhone 5 Rear Case Replacement: шаг 25, изображение 1 из 1
    • Remove the single 1.2 mm Phillips screw remaining in the mid-section logic board bracket.
    Спросите у FixBot
  26. iPhone 5 Rear Case Replacement: шаг 26, изображение 1 из 2 iPhone 5 Rear Case Replacement: шаг 26, изображение 2 из 2
    • Remove the mid-section bracket from the logic board.
    Спросите у FixBot
  27. iPhone 5 Rear Case Replacement: шаг 27, изображение 1 из 2 iPhone 5 Rear Case Replacement: шаг 27, изображение 2 из 2
    • Use a spudger to pry the Lightning connector cable connector up from its socket on the logic board.
    • Gently peel the cable back and out of the way of the logic board.
    Спросите у FixBot
  28. iPhone 5 Rear Case Replacement: шаг 28, изображение 1 из 3 iPhone 5 Rear Case Replacement: шаг 28, изображение 2 из 3 iPhone 5 Rear Case Replacement: шаг 28, изображение 3 из 3
    • Depress the SIM card release on the right side of the iPhone with a SIM card eject tool or a bent paperclip to eject the SIM card tray.
    • Alternatively, you can press the SIM card eject lever from the inside with the flat end of a spudger.
    • Remove the SIM card tray from the iPhone.
    Спросите у FixBot
  29. iPhone 5 Rear Case Replacement: шаг 29, изображение 1 из 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the following screws securing the logic board to the rear case:
    • Two 2.3 mm Phillips screws
    • Two 2.7 mm standoff screws
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • One non-magnetic 2.7 mm standoff screw
    • Be sure to put this screw back in its original position at the top of the logic board. A magnetized screw may interfere with the digital compass.
    Спросите у FixBot
  30. iPhone 5 Rear Case Replacement: шаг 30, изображение 1 из 3 iPhone 5 Rear Case Replacement: шаг 30, изображение 2 из 3 iPhone 5 Rear Case Replacement: шаг 30, изображение 3 из 3
    • Rotate the logic board assembly toward the battery side of the rear case.
    • Do not attempt to completely remove the logic board assembly from the rear case, yet; there is still one cable connected to the underside of the logic board.
    • The flash surround is adhered to the flash unit and the rear case. If it stays on the rear case remove with tweezers and mount it back on the flash unit.
    • Note: when reassembling your device, be sure that the lower interconnect cable is not tucked underneath the logic board.
    Спросите у FixBot
  31. iPhone 5 Rear Case Replacement: шаг 31, изображение 1 из 2 iPhone 5 Rear Case Replacement: шаг 31, изображение 2 из 2
    • Use the tip of a spudger to pry the Wi-Fi antenna cable connector up from its socket on the underside of the logic board.
    Спросите у FixBot
  32. iPhone 5 Rear Case Replacement: шаг 32, изображение 1 из 1
    • Remove the logic board assembly from the rear case.
    • While your logic board is out of your phone, keep it on a grounded anti-static mat to prevent any damage to the circuitry.
    Спросите у FixBot
  33. iPhone 5 Rear Case Replacement, Lightning Connector and Speaker Assembly: шаг 33, изображение 1 из 1
    • Remove the following screws securing the Lightning connector and speaker enclosure assembly to the rear case:
    • One 2.5 mm Phillips screw
    • Two 3.3 mm Phillips screws
    • One 2.9 mm Phillips screw
    • Two 1.5 mm Phillips screws
    • One 2.8 mm Phillips screw
    Спросите у FixBot
  34. iPhone 5 Rear Case Replacement: шаг 34, изображение 1 из 3 iPhone 5 Rear Case Replacement: шаг 34, изображение 2 из 3 iPhone 5 Rear Case Replacement: шаг 34, изображение 3 из 3
    • Use the flat end of a spudger to gently pry the Lightning connector and speaker enclosure assembly cables up from the rear case.
    • Make sure you get the spudger under the large ribbon cable connected to the assembly. Prying the rest of the assembly away from the cable may result in a tear.
    Спросите у FixBot
  35. iPhone 5 Rear Case Replacement: шаг 35, изображение 1 из 3 iPhone 5 Rear Case Replacement: шаг 35, изображение 2 из 3 iPhone 5 Rear Case Replacement: шаг 35, изображение 3 из 3
    • Remove the Lightning connector and speaker enclosure assembly from the rear case.
    • Take care not to lose the small metal washer on the speaker enclosure, or the four small metal washers beneath the Lightning connector screws.
    Спросите у FixBot
  36. iPhone 5 Rear Case Replacement, Vibrator: шаг 36, изображение 1 из 2 iPhone 5 Rear Case Replacement, Vibrator: шаг 36, изображение 2 из 2
    • Remove the following screws securing the vibrator bracket and motor to the rear case:
    • One 1.7 mm Phillips screw
    • One 1.6 mm Phillips screw in the top of the rear case
    Спросите у FixBot
  37. iPhone 5 Rear Case Replacement: шаг 37, изображение 1 из 1
    • Remove the vibrator bracket and motor from the rear case.
    Спросите у FixBot
  38. iPhone 5 Rear Case Replacement, Front Panel Clips: шаг 38, изображение 1 из 2 iPhone 5 Rear Case Replacement, Front Panel Clips: шаг 38, изображение 2 из 2
    • Remove eight 1.3 mm Phillips screws securing the front panel clips to the interior sides of the rear case.
    Спросите у FixBot
  39. iPhone 5 Rear Case Replacement: шаг 39, изображение 1 из 1
    • Remove the four front panel clips from the rear case.
    Спросите у FixBot
  40. iPhone 5 Rear Case Replacement, Rear Case: шаг 40, изображение 1 из 2 iPhone 5 Rear Case Replacement, Rear Case: шаг 40, изображение 2 из 2
    • Remove the following screws from the metal power switch bracket between the rear facing flash and camera windows:
    • Single 2.9 mm standoff screw
    • Standoff screws are best removed using an [связанный продукт отсутствует или отключен: IF145-343] and driver handle.
    • Single 1.6 mm Phillips screw
    • Remove the metal power switch bracket.
    Спросите у FixBot
  41. iPhone 5 Rear Case Replacement: шаг 41, изображение 1 из 2 iPhone 5 Rear Case Replacement: шаг 41, изображение 2 из 2
    • Remove the single 1.9 mm Phillips screw securing the power button bracket to the inside top of the rear case.
    • Use the tip of a spudger to rotate the power button cover down on its hinge.
    Спросите у FixBot
  42. iPhone 5 Rear Case Replacement: шаг 42, изображение 1 из 1
    • Remove the power button from behind its cover in the rear case.
    Спросите у FixBot
  43. iPhone 5 Rear Case Replacement: шаг 43, изображение 1 из 1
    • Use the tip of a spudger to press the power button cover in and lift it off of its hinge in the rear case.
    Спросите у FixBot
  44. iPhone 5 Rear Case Replacement: шаг 44, изображение 1 из 1
    • Remove the following screws securing the volume and silence buttons to the side of the rear case:
    • One 1.3 mm Phillips screw
    • Two 1.8 mm Phillips screws
    Спросите у FixBot
  45. iPhone 5 Rear Case Replacement: шаг 45, изображение 1 из 3 iPhone 5 Rear Case Replacement: шаг 45, изображение 2 из 3 iPhone 5 Rear Case Replacement: шаг 45, изображение 3 из 3
    • Pry the button cable away from the side of the rear case to expose the silence and volume buttons.
    • Remove the silence and volume buttons from the rear case.
    Спросите у FixBot
  46. iPhone 5 Rear Case Replacement: шаг 46, изображение 1 из 2 iPhone 5 Rear Case Replacement: шаг 46, изображение 2 из 2
    • Use the flat end of a spudger to pry the button cable up from the rear case.
    • Remove the button cable from the rear case.
    Спросите у FixBot
  47. iPhone 5 Rear Case Replacement: шаг 47, изображение 1 из 2 iPhone 5 Rear Case Replacement: шаг 47, изображение 2 из 2
    • Remove the single 2.0 mm Phillips screw securing the SIM card eject lever to the rear case.
    • Remove the SIM card eject lever.
    Спросите у FixBot
  48. iPhone 5 Rear Case Replacement: шаг 48, изображение 1 из 1
    • The bare rear case remains.
    Спросите у FixBot
Заключение
200 человек успешно провели ремонт по этому руководству.
Andrew Optimus Goldheart
Участник с: 10/17/09
515 398 Репутация
Автор 407 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 32 276 руководств
8 Комментарии к руководству
This guide does not describe removal of the wifi-antenna which seems to have taken place between step 32 and 34. For people new to electronics repair, such as myself, I feel this should be included in order to have a complete guide. I did a swap of the back casing yesterday myself, including the antenna and all went well (just a bit more nerve-wrecking removing parts not stated in the guide).
arvegrinden - Ответить Поделиться
You're so right!
isaac kovalyov - Ответить Поделиться
Replaced my rear case yesterday according to this guide, everything works :) just the power button pin was stuck on the old case and I had to make one from a paperclip, but still worked :)
robertscottyoravec - Ответить Поделиться
can you fix an iPhone 5 into an iPhone 5 c Housing
stabme99 - Ответить Поделиться
All this is fine, but there is a padding to the mic, the lightning port, the audio jack and the speakers that is provided in the original casing but is not there in any of the replacement cases. Without it, there is a gap that is very much visible and susceptible to dust and water seepage. Is there any way to resolve this?
Vivek Dwivedi - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 10
За последние 7 дней: 47
За последние 30 дней: 181
За всё время: 505,299
