iPhone 5c Power Button Replacement
Выберете то, что вам нужно
  1. iPhone 5c Power Button Replacement, Taping the display glass: шаг 1, изображение 1 из 3 iPhone 5c Power Button Replacement, Taping the display glass: шаг 1, изображение 2 из 3 iPhone 5c Power Button Replacement, Taping the display glass: шаг 1, изображение 3 из 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    Спросите у FixBot
  2. iPhone 5c Power Button Replacement, Removing the Pentalobe screws: шаг 2, изображение 1 из 1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.8 mm P2 Pentalobe screws on either side of the Lightning connector.
    Спросите у FixBot
  3. iPhone 5c Power Button Replacement, Starting the iSclack Opening Procedure: шаг 3, изображение 1 из 3 iPhone 5c Power Button Replacement, Starting the iSclack Opening Procedure: шаг 3, изображение 2 из 3 iPhone 5c Power Button Replacement, Starting the iSclack Opening Procedure: шаг 3, изображение 3 из 3
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 5c that we recommend for anyone doing more than one repair on an iPhone 5, 5s, or 5c. If you aren't using the iSclack, skip to Step 5.
    • Close the handle on the iSclack, opening the suction-cup jaws.
    • Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
    • The top suction cup should rest just above the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
    Спросите у FixBot
  4. iPhone 5c Power Button Replacement, Finishing the iSclack Opening Procedure: шаг 4, изображение 1 из 2 iPhone 5c Power Button Replacement, Finishing the iSclack Opening Procedure: шаг 4, изображение 2 из 2
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on to Step 8.
    Спросите у FixBot
  5. iPhone 5c Power Button Replacement, Manual Opening Procedure: шаг 5, изображение 1 из 1
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    Спросите у FixBot
  6. iPhone 5c Power Button Replacement, Start lifting the front panel assembly: шаг 6, изображение 1 из 2 iPhone 5c Power Button Replacement, Start lifting the front panel assembly: шаг 6, изображение 2 из 2
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
    Спросите у FixBot
  7. iPhone 5c Power Button Replacement: шаг 7, изображение 1 из 1
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
    Спросите у FixBot
  8. iPhone 5c Power Button Replacement, Opening up the phone: шаг 8, изображение 1 из 2 iPhone 5c Power Button Replacement, Opening up the phone: шаг 8, изображение 2 из 2
    • Lift the home button end of the front panel up to gain access to the connectors near the top of the phone.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, you can use an unopened canned beverage to hold the display.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    Спросите у FixBot
  9. iPhone 5c Power Button Replacement: шаг 9, изображение 1 из 1
    • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
    Спросите у FixBot
  10. iPhone 5c Power Button Replacement: шаг 10, изображение 1 из 1
    • Remove the metal battery connector bracket from the iPhone.
    Спросите у FixBot
  11. iPhone 5c Power Button Replacement, Disconnecting the battery connector: шаг 11, изображение 1 из 1
    • Use a spudger or a clean fingernail to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
    Спросите у FixBot
  12. iPhone 5c Power Button Replacement: шаг 12, изображение 1 из 1
    • Remove the following Phillips #000 screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.3 mm screws
    • One 1.7 mm screw
    • One 3.25 mm screw
    • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 3.25 mm screw or the 1.7 mm screw in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
    • Be careful not to over-tighten the screws. If they don't fit easily when you are securing them, they may be the wrong size—don't force them.
    Спросите у FixBot
  13. iPhone 5c Power Button Replacement: шаг 13, изображение 1 из 1
    • Remove the front panel assembly cable bracket from the logic board.
    Спросите у FixBot
  14. iPhone 5c Power Button Replacement, Disconnecting the front panel assembly cables: шаг 14, изображение 1 из 2 iPhone 5c Power Button Replacement, Disconnecting the front panel assembly cables: шаг 14, изображение 2 из 2
    • Use a plastic opening tool or a fingernail to disconnect the front-facing camera and sensor cable connector.
    • Be sure to only pry up on the connector, and not on the socket on the logic board.
    Спросите у FixBot
  15. iPhone 5c Power Button Replacement: шаг 15, изображение 1 из 3 iPhone 5c Power Button Replacement: шаг 15, изображение 2 из 3 iPhone 5c Power Button Replacement: шаг 15, изображение 3 из 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the LCD cable connector.
    • The LCD and Digitizer connectors are on the same cable assembly, so prying the LCD connector up should disconnect both connectors. Double check that the two cables are fully disconnected before removing the display.
    • When reassembling your phone, the LCD cable may pop off its connector. A blank screen, or white lines on the display could be caused by a loose connection. Should this happen, reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
    Спросите у FixBot
  16. iPhone 5c Power Button Replacement, Separating front panel assembly and rear case: шаг 16, изображение 1 из 1
    • Remove the front panel assembly from the rear case.
    Спросите у FixBot
  17. iPhone 5c Power Button Replacement, Rear-Facing Camera: шаг 17, изображение 1 из 1
    • Remove the two 1.5 mm Phillips #000 screws securing the rear-facing camera to the rear case.
    Спросите у FixBot
  18. iPhone 5c Power Button Replacement: шаг 18, изображение 1 из 1
    • Remove the rear-facing camera bracket from the iPhone.
    Спросите у FixBot
  19. iPhone 5c Power Button Replacement: шаг 19, изображение 1 из 1
    • Use the flat edge of a spudger to pry the rear-camera connector up off the logic board.
    Спросите у FixBot
  20. iPhone 5c Power Button Replacement: шаг 20, изображение 1 из 1
    • Remove the rear-facing camera from the iPhone.
    Спросите у FixBot
  21. iPhone 5c Power Button Replacement, Power Button: шаг 21, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the following screws securing the upper assembly contact bracket to the rear case:
    • 3.0 mm standoff screw
    • Standoff screws are best removed with a standoff screwdriver or standoff driver bit. A small flathead screwdriver can also do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • 1.5 mm Phillips #000 screw
    Спросите у FixBot
  22. iPhone 5c Power Button Replacement: шаг 22, изображение 1 из 3 iPhone 5c Power Button Replacement: шаг 22, изображение 2 из 3 iPhone 5c Power Button Replacement: шаг 22, изображение 3 из 3
    • Remove the upper assembly contact bracket from the rear case.
    • A small rubber bumper may fall off the top of the bracket—take care not to lose it.
    Спросите у FixBot
  23. iPhone 5c Power Button Replacement: шаг 23, изображение 1 из 1
    • Remove the small foam tape from inside the rear camera's cavity.
    Спросите у FixBot
  24. iPhone 5c Power Button Replacement: шаг 24, изображение 1 из 1
    • Remove the two 1.4 mm Phillips #000 screws securing the power/sleep button bracket.
    Спросите у FixBot
  25. iPhone 5c Power Button Replacement: шаг 25, изображение 1 из 3 iPhone 5c Power Button Replacement: шаг 25, изображение 2 из 3 iPhone 5c Power Button Replacement: шаг 25, изображение 3 из 3
    • Use the pointed end of a spudger to gently fold the power/sleep button bracket down from the top of the rear case.
    • Use tweezers to grab and remove the button.
    • For reassembly, note the orientation—the metal bar should be flush with the bottom of the button. Check if your home button has the metal hinge, if not you will need to transfer it from your current home button.
    • If you can't get a hold on the power button from inside the case, use a spudger to slightly push it in from the outside.
    Спросите у FixBot
Заключение
45 человек успешно провели ремонт по этому руководству.
Andrew Optimus Goldheart
Участник с: 10/17/09
514 907 Репутация
Автор 407 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 25 719 руководств
8 Комментарии к руководству
So whats next,if you removed it and reintalled it and still dont work. What next??
ZULEYMA - Ответить Поделиться
This should not be rated "difficult" because it's extremely easy.
THIS is difficult.: iPhone 5c Audio Control and Power Button Cable Replacement
applerepairshop - Ответить Поделиться
Yes, this one is relatively easy.
Anything involving a heat gun is "Difficult ".
Anything involving mandatory spare parts and a heat gun is "Very Difficult ".
Boyd Waters - Ответить Поделиться
There is a cable connected to be power button on my iPhone c and all the videos don't show how to remove it HELP PLEASE
Perry Harrison - Ответить Поделиться
You can find the guide for removing/replacing the cable for the power button right here. That cable also contains the flash, microphone, and volume controls.
Jeff Suovanen - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 15
За последние 30 дней: 106
За всё время: 45,512
