Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
Инструмент, используемый на этом этапе:Anti-Clamp$24.95-
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Pull the plastic nub to release the vacuum seal on the suction cup.
Remove the suction cup from the display assembly.
Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95-
Remove the following Phillips screws from the battery connector bracket:
One 2.2 mm screw
One 3.2 mm screw
Remove the metal battery connector bracket from the iPhone.
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following five Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.7 mm screw
One 3.1 mm screw
Remove the front panel assembly cable bracket from the logic board.
Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
Use a spudger or a fingernail to disconnect the home button cable connector.
Use a spudger or a fingernail to disconnect the display data cable connector.
Use the flat end of a spudger to disconnect the digitizer cable connector.
Remove the following Phillips screws from the earpiece speaker/front-facing camera bracket:
One 2.3 mm screw
One 3.0 mm screw
One 2.2 mm screw
Remove the earpiece speaker/front-facing camera bracket from the front panel.
Lift the front-facing camera out of its recess in the front panel.
Holding the front-facing camera out of the way, remove the earpiece speaker from the front panel.
331 участников успешно повторили данное руководство.
26 Комментариев
Holy crap, ordered the replacement speaker and the $24 tool kit, followed this website and in 15 minutes (plus a baby diaper change in the middle) my wife's iphone 6 was working through the ear piece again! Super informative instructions - I like the color code on the screw sizes so I could sort them in trays during removal. Thank you ifixit! You saved me hundreds of dollars! The hardest part was snapping the cable connectors back in, I was very cautious not to force them in but other than that it was a breeze.
What kit would you recommend me?
ceaggar -
My husband dropped his iPhone 6 in a glass of water. He immediately pulled out, dried it and put it in a glass with rice. He tried to arrest him but did not work. He opened it and had water. it dried, he reassembled but did not detect the SIM card. The phone works but is not heard nothing.
I just changed the ear speaker on my iphone 6. The damage was caused by water. After thr replacement and a full factory reset the ear speaker is still not working. I read that it could be the cable however the camera, proximity sensor and everything else seems to be working, only the ear speaker still doesnt work.
Any ideas?
Thanks
